RIM BlackBerry  Pearl  8100 Logo
Posted on May 28, 2009
Address book All of a sudden the entire address book is gone, personal and business. Tried to synchronize with desktop computer and still does not show up. Says address book is empty. Can still voice activate a call to any of the names in the address book but not there to view. yea i have the same problem how do i get it back to the way is was before
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jun 02, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
30648
Points
Open your 'empty' address book and click on the MENU button (left of the rotater wheel) and select FILTER and UNCHECK anything that is checked there. All your addresses should reappear. It happened to me and I have no idea how it happened, but it was a relief to get them all back so easily. Hope that works.
2helpful
2answers
Cant get predicted email addressed
the email function is tied to your address book, if you do not have the address book filled out with email addresses, or have emailed that person from the tablet before they will not show up in the FAYT address box
I’m happy to assist further over the phone at https://www.6ya.com/expert/gregg_78ecbb34e27be215
When i pull up my address book, it show "Business" contacts...I am unable to change it to "Personal" address book. Any suggestions?
To change it to personal contacts follow the bellow mentioned steps:
1) Select adress book
2) Press menu
3) Select filter
4) Check on personal
5) and you can enter ur contacts under personal contacts.
RIM Messages
You have to uninstall your desktop manager from your computer again. Then on your phone, go to settings, options, advanced options, service books. You should see some "desktop" service books there. Delete all the service books with "desktop" in the name. Then reinstall the desktop manager and make sure you choose the option for "personal" email and not business email-even if it is business email. The phone is trying to communicate with an enterprise server and you obviously don't use one.
How to transfer my black berry address to my new iphone
Hi Here are the steps
1) Load up Blackberry Desktop Manager 2) Click "Synchronize" 3) Click the "Configuration" tab at the top of the screen. 4) Click the "Configure Synch" button 5) Click on "Address Book". 6) If it doesn't take you to configuration automatically, click "Setup" 7) Select "Microsoft Outlook Express". 8) Select "One way sync from Device" and "Replace all data in the target application 9) Click "Use existing Main Identity 10) Click "Finish" - this should bring you back to "Select Device Application" where it should show you something like Address Book ---> Microsoft Outlook Express 11) Click "Ok" 12) Click on the "Synchronize" tab at the top. 13) Click "Synchronize now". It should go through a whole bunch of screens, eventually showing a confirmation dialog to confirm address book edits. 14) Click "Accept" 15) Your contacts should now be in Outlook Express. 16) Close BB Desktop Manager 17) Open iTunes if you don't have it open already. 19) Go to your iPhone's setup page in iTunes (click on the iPhone along the side menu) 20) Click on the "Info" tab 21) Under "Contacts", check the "Sync contacts with" checkbox, and select "Windows Address Book". "All contacts" should be automatically selected. 22) Click "Apply" at the bottom of the page. It should save your changes, and automatically sync your contacts. The following steps is only necessary if you don't intend to keep your iPhone synched with Outlook Express's address book (which I imagine is the case for most people). 23) Uncheck the "Sync contacts with" checkbox. 24) Click "Apply" at the bottom of the page
This shoulds help and please do let me know if your issue is solved
9helpful
Address book won't show contacts
Go into your Address book
Hit the Menu Button
Go to Filter
Make sure that both the business and personal box's are NOT checked
If they are checked you need to uncheck them
This should restore your contacts... If it does not restore them then you have a Bigger Issue!!!
2answers
Outlook 2007 - address book
Right click on the contacts folder and check the box show my contact in address book
Good evening....i think i left my palm "on" & not charged last night. i opened it this afternoon & it was a white screen that said RESET. i tried to turn on or off & pressed restart...
Hi, from the sounds of your situation, im sorry to tell you that your address book is gone. If you have hotsync with your desktop before, you may be able to retrieve a copy of your address book from your last sync. Otherwise there are companies available to recover data from pdas but their services are very expensive.
12helpful
4answers
Address book
That's easy just goto your address book
2.press the menu button
3.select filter
4.press the menu button again
5.and select uncheck filter'
thats should make your contacts reapear
2answers
How do I copy address book and calendar from Tungsten E to Outlook?
In order to synchronize with Outlook you need to setup the replication to be with Outlook instead of Palm Desktop. On you cd there should be a third party piece of software (Chapura). Install the required software and follow the instructions.
Synch question
If you have PocketMirror from Chapura (included with certain Palm handhelds), you can choose to install conduits that synchronize MS Outlook with the handheld applications Date Book, Address Book, To Do List, and Memo Pad. You can choose to synchronize these applications with either Palm Desktop or Microsoft Outlook, but not both. If you want to synchronize with Microsoft Outlook, DO NOT install Palm Desktop from the Web. Instead, run the Palm Desktop installer from the CD that came with your handheld and select the option "Synchronize with Microsoft Outlook" when the choice appears. Visit www.PocketMirror.com for more information about Chapura(R) PocketMirror.
Top RIM Computers & Internet Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Alexander
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
