Installed the jensen 9511TS and got everything to work so far but when i connect an IPOD the screen doesnt register it... I cant access the IPOD thru the deck... The IPOD itself actually shows that it is charging tho... I have the J-link cord and its hooked up to the media center and i already did a reset and still it wont read it... any ideas??
thanks
Try changing the drive letter, follow this link to change it http://www.methodshop.com/gadgets/tutorials/driveletteri/index.shtml
SOURCE: Jensen VM9511TS... Problem
Try a hard reset. If you look on the face of the unit, you will see a little pinhole located on the lower right side, stick a paper clip in there and hold in until the system reboots itself, this should be done while on.
SOURCE: parking brake disable model jensen 9511ts
on the jensens, there is a way to disable the parking brake without having to put a switch on the parking brake wire. the catch is that you will need the remote control to get into the service menu. follow these steps
1.turn the radio on and select the setup menu.
2. while in the setup menu, use the remote and press 5-4-3-2-1-0, this should access another service menu.
3. from there, you will see a brake override option.
4. and your done.. hope this helps
if for any reason yours doesnt offer this option. you can always put a switch on the ebrake wire of the screen.
1. use a 2 wire toggle and wire one side the ground and the other to the parking brake wire on the jensen. then do the pattern on the switch instead of using your ebrake.
Testimonial: "somewhat helpful just not sure what e ment by do the pattern on the switch instead of the ebrake.?"
SOURCE: is a media link box and media module the same for jensen vm9311ts
do i need a media module to play movies with my jensen vm9411 and i dont have my remote either so how can i bypass watching dvd while driving and yes i know its illegal but im not going to be watching it my kids will be thanx
SOURCE: Bought an iPod cable for my clarion vrx485vd.
Reset the unit (tiny button on the front of the unit). What cable are you using? Have you had a Clarion dealer check it out?
Its an 80GB video IPOD i think
yes i tried to cycle thru with the source button and also on the touch screen menu... On the TS menu IPOD is kinda gray... like the navi that i dont have... its as if the IPOD isnt there at all
an obvious question...but I need to ask...have you cycled thru the source button on the radio to "ipod"?
what model of ipod?
some of the jlinks won't work with the latest generation of ipods and touches..
