Light shadows on Sanyo HD screen
We have a 32'' Sanyo HD. It is about three years old. Recently we have shadows forming on one area of the screen. They look like gray clouds that are translucent. On first glance it looks like a dirty screen, but unfortunately it isn't.
  • Televison & ... Master
  • 2,005 Answers
Check you cold cathodes they are going out
Posted on May 28, 2009
SOURCE:
My three year old grandson stepped on his table and now it has a "shadow" on the screen. Is this repairable?
probably not. Without seeing it I would guess the backlight has torn away from the screen. You may be able to just replace the screen but I haven't tried.
Jan 28, 2015 | Amazon Kindle Fire HD 8.9"
Slight shadow on part of screen
Hi, There have been several problems lately with the screens doing that. The only way is replacing the screen. I have located the problem causing it, It is the light filters in the panel,not replaceable at this time."pain in *** too"Did it from a broken panel. The light filters diffuse the light evenly so you do not notice the backlights. If you bend it,it will cause shadows like your getting. They heat up and swell a bit. And that is what is causing it. I have contacted Samsung,And Magnavox about the problem. Will not sell replacement light filter at this time tho.The LED backlit will not do this. They run cool.
If I can help you out more contact me at...
toddthetvmd@yahoo.com
Oct 31, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
No picture, no sound.
contact sanyo, sounds like your display panel has gone bad
Sep 08, 2009 | Sanyo DS31590 31" TV
HD TV not passing the tests offered on network tv
Which network? Cable? Satellite? Dish or Direct?
With any of these providers, you should get an ATSC or "digital" signal. If not, the problem would most likely be with the service provider since they are converting the signal for you. The only way that your set would be affected is if you have an "off air" (antenna) signal only. At this point you would need a converter box. If your service provider is providing you with a HD receiver, then you should have no problem recieving HD (as long as your paying for HD). However, keep in mind, digital is NOT HD. If there is an incompatability with your receiver, check with your service provider for a software or hardware upgrade. Also, check with your local TV serviceman to find out if there are any software upgrades (firmware) for your TV. Being three or so years old, it is possible.
One last thing to check is to see what type of signal you are passing from your providers box to your TV (which type of cable". At a minimum, you need a "component" connection to pass HD content. A "composite" signal is standard definition. Best you can get right now is an HDMI cable. Best "one cable" source for video and audio.
Good Luck.
Tim
Certified TV
Jan 23, 2009 | Sanyo DP32746 32 in. LCD Television
Sanyo TV 37647
next time dont get water on it and if you pushed too hard when you wiped it that makes it worse.
Aug 07, 2008 | Sanyo DS32830H 32" TV
"melting" screen image
the problem is the backlight not lit evenly.
have the backlight inverter board checked for correct ac ht and if that is okay then u will have to replace the backlight.
Jul 10, 2008 | Polaroid Televison & Video
Problem with Sanyo 32
your problem is in the pin cussion ,so change the capacitor around connect to pin cussion area or if you can see a trimer in that area try to adjust or else resolder you tv.
Apr 22, 2008 | Sanyo HT32744 32" TV
Shadow on the screen
our 32 inches flate p tv is not turning on an off no power
please help
Feb 09, 2008 | Sanyo DP32746 32 in. LCD Television
32 in sanyo tv
no. the tv has to be built for hd. if you want to watch true hd you have to have an hdtv.
Jan 18, 2008 | Sanyo DS27510 27" TV
Televison & Video Logo
232 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
