Question about Microsoft Windows Vista Business Edition for PC
Windows vista restarts on shutdown - Microsoft Windows Vista Business Edition for PC
How do I restart or reboot my whole system and start fresh.I have a Dell latitude D430
Dell not given facility to reboot. But command through you can reboot . To access the command prompt window from Vista or Windows 7:
  1. Go to the Start menu
  2. Type cmd in the Search field
  3. Press Enter
On a Windows XP computer:
  1. Click the Start menu
  2. Choose Run
  3. Type cmd
  4. Press Enter
From an open command prompt window, you can type shutdown, and then the option you wish to execute.
To shut down your computer type: shutdown /s
To restart your computer type: shutdown /r
To log off your computer type: shutdown /l
0r
press down window key with and two time press "U" key.
Sep 19, 2013 | Computers & Internet
Tip
Create Desktop Shutdown/Lock/Restart/Hibernate Shortcut Icons In Vista
1. Right click an empty area of your Desktop
2. Select New>> Shortcut
3. In the text box titled: "Type the location of the item:" Enter the Command for the particular shortcut you would like to create. I've listed all of the commands below that activate their respective shortcut:
Hibernate rundll32.exe PowrProf.dll,SetSuspendState
Lock Rundll32.exe User32.dll,LockWorkStation
Restart Shutdown.exe -r -t 00
Shutdown Shutdown.exe -s -t 00
Sleep rundll32.exe powrprof.dll,SetSuspendState Sleep
4. Once you've entered the command, click "Next"
5. Vista will now ask you what you would like to name your shortcut. I've always just given it the name of its function (EG: Shutdown or Shutdown System).
6. Once you have named you shortcut, click "Finish". Your new shortcut will now reside on your Desktop. Simply double click the icon to activate the command.
Note: If you do not like the look of the "default" icon that Vista has given it, you can change the icon to a different one. Here's how:
1. Right click the shortcut icon
2. Select Properties
3. The shortcut properties window will now be displayed. Click the "Change Icon" button.
4. The "Change Icon" window will now appear. Here, you can select from the many available system icons. Click the icon that you would like to use as your shortcut icon and then click OK.
Your Desktop shortcut icon will now revert to the selected system icon.
That's it! Have fun!
on Oct 08, 2010 | Computers & Internet
Tip
How to restart or shutdown a computer through a remote desktop connection
When you are connected to another computer by remote desktop, did you ever notice that the shutdown and restart options are not there. The computer that you remote desktop to must already be on. But if you regularly use remote desktop, at some stage you will want to restart the remote computer from where you are. For example you might install a program and you need to restart the computer to finish the installation. If this doesn't happen automatically then you can follow the steps below.
How to Reboot or Shutdown a Machine from Remote Desktop Connection using Windows XP?
  1. Open the run box by pressing the WINKEY and the letter R on the keyboard.
  2. Type the following command into the run box: shutdown -r -f
  3. Press Ok.
  4. This will restart the remote computer.
If you would like to shutdown the Windows Xp remote computer you can type: shutdown -f
When you are typing these commands in you must type it exactly right. If you miss a space or a dash it will not work.
Restart a remote computer using Windows Vista or Windows Seven.
On these newer operating systems the run box is almost obsolete. You only have to open the start menu and type these commands into the search bar at the bottom. This area acts as a run box and you can type commands into this.
on Jan 29, 2010 | Computers & Internet
How can i reboot my computer please
Rebooting a computer means, pressing the Reset/Restart button. But if you wish to securely restart it, click Start (Windows XP) and then "ShutDown" button, again click "Restart". There's another option when Windows XP is in Classic mode, once you press the Shutdown button, you'll see a small window showing "Shutdown", you can click the arrow button next to the "Shutdown" and then select "Restart", now click the "Ok" button to restart the system. In Windows Vista and Windows 7, click "Start", if you don't see the "Restart" button, you might be seeing the "Shutdown" button, just next to the "Shutdown" button, there's a small right arrow button, click it and select "Restart". Your system will restart.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Sep 05, 2011 | Acer Aspire 5500 5570-2609 Laptop
How can i reboot my acer laptop
Press Start(ORB at bottom left for vista/w7) and if you're on windows 7/vista, there should be a list button on the bottom right side of the start menu saying "Shutdown"(windows 7) and "Sleep"(Vista), click the list and click Reboot.
On XP you need to click the Shutdown button and before you click shutdown instead click Reboot(Green button If i recall correctly).
Jul 15, 2011 | Computers & Internet
How can i restart a pc any type ?
In Windows XP click Start-->Turn Off Computer-->Restart
In Vista/W7 click Start (Windows Icon)-->Click the little arrow beside "Shutdown" then click restart
Oct 25, 2010 | Computers & Internet
Desktop shortcuts for shutdown, standby & hibernate
Win + Right Arrow + Enter Sleep Mode Win + Right Arrow (x3) + Enter Shut Down Win + Right Arrow (x3) + U Shut Down Win + Right Arrow (x3) + R Restart Win + Right Arrow (x3) + W Switch User
That is for vista. Is this what you need?
From http://lifehacker.com/282341/shutdown-restart-and-sleep-vista-from-the-keyboard
Jan 15, 2010 | Intel Motherboard
How do i reboot my windows vista
booboofayce3
To restart Windows Vista click on the Winows Peril or press the Windows button to bring up the Start Menu. Next click on the triangle that is to the right of the shutdown button. There you will get a drop down that has the restart option in it. Clicking on the restart will restart the computer.
Issken
Jan 11, 2010 | Microsoft Windows Vista Home Premium...
HP-520 shutdowns while restaring after vista updates installed
This is something you no longer have to worry about. Vista is no longer being supported so Microsoft will no longer be releasing new updates.
Windows Vista Reaches End of Life Capital Support
May 06, 2017 | E-Machines M5310 PC Notebook
Windows Vista will Shutdown but will restart in immediately
You can create a shutdown icon on your desktop that might resolve your issue.
  2. In the shortcut location box, enter
    • Shutdown.exe -s -t 00
  3. When you've clicked 'Next...', you'll be asked to name the shortcut. Probably best to name it 'Shutdown'
  4. After you click 'Finish' you should now have a new icon that you can double-click to shutdown your computer.
Hope this helps! : )
Jun 28, 2008 | Microsoft Windows Vista Home Premium with...
Microsoft Windows Vista Business Edition for PC Logo
21 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
