I deregistered all handsets from base unit. My base unit still shows all the 10 handsets are already registered with it. I want to reset the base inorder to reregister the handsets. What is the solution for this.
Thanks
Uniden TRU9485 (This didn’t work for me but this was the first instruction from Uniden Tech Support)
TO RESET THE BASE UNIT:
Unplug the base unit AC adapter.
Hold down for 15 seconds the DND, * and “menu” soft key (the middle silver soft key under the LCD) while plugging the base unit AC adapter back in.
All the settings should be reset.
Uniden TRU9485 (Worked for me)
ALTERNATE WAY TO RESET THE BASE UNIT:
Hold down for 15 seconds the DELETE KEY (zero with a line through it) while plugging base unit AC adapter back in.
I do not have my Panasonic KX-TGA110EX basis, how can I do to register., Please help me
No reset 9485
I had a TRU9485-2 base unit with a non-existent handset still registered that wouldn't clear out. Using the "Hold down DND, * and middle soft key while powering up base unit" method did the reset perfectly. Thanks!
You may need to reset your handset in the following instances:
You lose a handset and purchase a new one. When you try and register to your existing base you get registration
failure.
You are unable to register any handsets to the base.
You had a base which needed to be exchanged by the manufacturer. When you register your existing handsets
to the base, the handsets say #3 and #4, but you only have 2 handsets.
When you are instructed to by the one of the manufacturer's call center representatives.
To reset, do the following:
Press and hold [ ] and [#] for more than 5 seconds. Select DEREGISTER HS.
WHICH HANDSET? appears. Select the handset that you want to de-register, and press the OK soft key.
DEREGISTER HS appears. Select YES, and press the OK soft key.
ARE YOU SURE? appears. Select YES, and press the OK soft key. You will hear a confirmation tone. The
handset will clear its registration information from the base, and then delete its own base information.
MODELS VARY! PLACE HANDSET ON THE BASE FOR REGISTRATION OR REFER TO OWNER'S MANUAL. To
re-register the handset to the base (see page 25).
If the handset cannot contact the base, it will display OUT OF RANGE. Make sure the handset is in range of the
base and the base is connected to power.
Note: It is also possible to reset the handset back to its original factory settings. All changes including Caller ID information
will be erased. For more information on resetting the handset back to factory settings and when you need to
do this, see www.uniden.com or call our Customer Service Hotline. See back cover page for contact information.
Resetting the Handset without the Base
If your original base is not available for some reason (for example, it is lost or somehow incapacitated), you can still
reset the handset and use it with another base.
Move the cursor to select BASE UNAVAILABLE and then press the OK soft key.
BASE UNAVAILABLE appears.
Move the cursor to select YES, and then press the OK soft key. ARE YOU SURE?
appears.
Move the cursor to select YES, and then press the OK soft key. You will hear a confirmation tone. The handset
will delete its own base information without trying to contact the base. When the base information is deleted,
the handset displays MODELS VARY! PLACE HANDSET ON THE BASE FOR REGISTRATION OR REFER
TO OWNER'S MANUAL. Register the handset to the new base (see page 25). of its user manaul.
OK.
