Cell Phones Logo
Posted on May 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have forgotten my security code for nokia 6125.now how can i reset it
I have forsgotten my security code for nokia 6125.now how can i reset it
Resolution IT Dubai
Level 3:
Guru:
  • Master 541 Answers
  • Posted on May 30, 2009
Resolution IT Dubai
Master
Level 3:
Guru:
Answers
541
Questions
Helped
231377
Points
1629
Hi Friend,
Kindly check it with the below mentioned code
*#7328748263373738#---resets the security code
If it doesnt work,kindly provide the IMEI Number ,u can get this number by typing *#06# or at the back of the mobile u will have this number.
check and revert back
Regards,
Ayyasam
Reset security code
These WEB sites may help reset your Nokia security code
RESET NOKIA SECURITY CODE
http://tjosm.com/reset-forgotten-nokia-security-code/
Nokia security code if it does not work use nemesis service suit
http://mastercode.nokiafree.org/
How to change security code on old nokia phone coz i cant remember anymore.
So you don't know or you have forgotten your Nokia Security code? No data cable needed with this new solution.
So what is a master code?
Well lets assume you have forgotten your security code. The master code is a 10 digit number that will always be accepted as if it were your actual security code.
You can then use the master code to change your security code back to what ever you like. When your Nokia handset asks you for the security code simply enter the master code.
Will work on all of DCT3 generation, like:
2100, 3110, 3210, 3310, 3315, 3330, 3350, 3390, 3410, 3610, 5110(i), 5130, 5190, 5210, 5510, 6080, 6110, 6130, 6138, 6150, 6190, 6210, 6250, 7110, 8210, 8250, 8290, 8850, 8855, 8890, 9110(i), 9210(i), 9290.
Will work on most of DCT4 generation, like:
3100(b), 3108, 3120, 3200(b), 3220, 3230, 3300, 3360, 3510(i), 3530, 3590, 3595, 3600, 3650, 3660, 5100, 5140(i), 6020, 6021, 6100, 6101, 6108, 6200, 6220, 6230(i), 6260, 6310(i), 6500, 6510, 6590, 6600, 6610(i), 6620, 6650, 6800, 6810, 6820, 6822, 7200, 7210, 7250(i), 7260, 7270, 7280, 7600, 7610, 7650, 7700, 7710, 8310, 8390, 8800, 8910(i), 9300(i), 9500, N-Gage (QD).
Will NOT work on some of DCT4 generation, like:
1100(B), 1101, 1110, 1112(i), 1600, 2300, 2310, 2600, 2610, 2650, 2652, 6030(B), 6060, 6111.
Will NOT work on any of BB5 generation (all newest phones), like:
3250, 5300, 5400, 5500, 6125, 6131, 6233, 6234, 6280, 6282, 6630, 6680, 6681, 6682, 7370, 7373, 7390, all E-series, all N-series.
PC Version:
Read more: http://cellphoneforums.net/nokia/t272372-reset-nokia-security-code.html#ixzz2DsgO8ArZ
Dec 02, 2012 • Cell Phones
30helpful
16answers
Security code of Nokia 1280
YOUR Master Security Code is 1226602641
13helpful
Hello i need master code for nokia E75 p help me
NOKIA E75 falls under BB5 group..and its master code can't be generate by master generator.. but for this solution you can try it..
Nokia BB5 Security mastercode reset
These newer BB5 phones require software to reset the security code:
Nokia 3250, Nokia 6125, Nokia 6131, Nokia 6270, Nokia 6280, Nokia 6630, Nokia 6680, Nokia 6681, Nokia 6682, Nokia 7370, Nokia E50, Nokia E60, Nokia E61, Nokia E62, Nokia E70, Nokia N71, Nokia N72, Nokia N73, Nokia N80, Nokia N90, Nokia N91, Nokia N92, Nokia N93,
Nokia BB5 security code reset procedure:
* Connect your phone via USB cable in pc mode
1helpful
4answers
I have forgotten my security code and want to reset
Dear please enter code 12345 or 1122 or 0000 if these are not accepted then please reinstall its software. Problem will be quickly solved. Regards
1helpful
Forgotten security code
Try the reset code:
*#7328748263373738#
Then your securtiy code should be reset to :12345.
Please rate...
5helpful
4answers
3110c problem
So you don't know or you have forgotten your Nokia Security code? Don't worry the solution lies in this very page! No data cable needed with this new solution. All you need is a Master Code! Forgetting your security code can be frustrating. For example You need this code when you want to reset your phone settings.
So What is a Master Code I Hear you Ask? Well, lets assume you have forgotten your security code. The master code is a 10 digit number that will always be accepted as if it were your actual security code.
You can use the master code to change your security code back to what ever you like. When your Nokia handset asks you for the security code simply enter the master code.
How do you Generate the Master Code? The master code is specific to your handset and is generated using the handset 15 digit IMEI number (serial number). The IMEI number can usually be found on the sticker underneath the battery or by typing *#06# into the phone keypad.
Simply enter your 15 digit serial / IMEI number into my online tool (see link below). Your master code will then be calculated instantly.
Which Nokia Models will this work for? The calculated master code will only work for DCT3 and DCT4 Nokia phones. It will not work with the newer BB5 handsets. See below for a rough guide or look at my Nokia generation list to check if your model is supported. The feedback I have received is that's IT WILL NOT WORK FOR THE 6230i model (the 6230 is fine).
Compatible phone models
  • DCT3 2100 3210 3310 3330 3410 402 5110 5210 5510 6110 6150 6210 6250 6500 7110 8210 8250 8850 8890 9000 9100 9210
  • DCT4 1100 1101 1110 1600 2300 2600 2650 3100 3120 3200 3220 3510 3510i 3650 3660 5100 5140 6020 6021 6030 6060 6070 6080 6100 6101 6103 6170 6111 6220 6230 6260 6310 6310i 6510 6810 6820 6822 7200 7210 7250 7250i 7260 7270 7280 7360 7600 7610 7650 7700 8310 8800 8910 8910i
Incompatible models
  • BB5 5500 Sport, 6131, 6125, 7380, 7360, 7370, E70, E61, E60, 3250, 6280, 6681, 6680, 6630, 6233, 6151, E50, 7390, 7373, 5200, 5300, 6136, 6288, N70, N71, N72, N73, N80, N91, N93, N70 Music Edition, N95, N91 8GB, 6300, 6086, N76, N93i, N73 Music Edition, E90, 3110 classic, 6110 Navigator, E65, E61i, N80 Internet Edition, 5700, 5070, 6120 Classic, 1650, 2630, 1200, 1208, 2760, 3109 Classic, 6500 slide, 3500 classic, 6267, 6121 classic, N81 8GB, N81, N95 8GB, 7900 Prism, 7500 Prism, 6555, 5610, 5310, E51, 6301, N810, N82, 3110 Evolve, 8800 Arte, 8800 Sapphire Arte, 3120 classic, 2600 classic, N78, N96, 7900 Crystal Prism etc.
  • ASIC 11 2760, 2626, 2660, 2630, 2610, 2610b, 1112b, 1112, 1110i, 1200, 1200b, 1208, 2310, 8800 Sirocco
I plan to write a security code tutorial for BB5 handsets shortly (sadly the solution for these handsets is not as simple)
Please Note:
The default security code for ALL Nokia handsets is 12345
This is sometimes called the phone lock code.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
