Wolf Manufacturing  Gas Kitchen Range Logo
Posted on May 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wolf Sealed Rangetop Stopped Igniting
My fairly new wolf rangetop stopped igniting while I was using it! I can hear the gas turn on but the igniter and the "ticking noise" doesn't happen now.
Shane Hays
Level 2:
Scholar:
  • Expert 82 Answers
  • Posted on May 28, 2009
Shane Hays
Expert
Level 2:
Scholar:
Answers
82
Questions
Helped
32933
Points
161
Do any of the burners click? If not, you may need a new spark module. If only one isn't clicking you may need a new ignition switch that is just behind the knob. I have also seen wires get pinched,stopping the flow of electricity. It may also be a computer board issue which is rare. Sooo you really need to call for service.
Bluestar rangetop clicks several times before igniting
Do other appliances in your home using LP gas work properly? If so, then this is probably an air/fuel mix problem on the burner(s). If this is a new rangetop there should be directions with the range and the LP conversion kit to instruct on proper adjustments. Be certain the correct LP orifice was installed for each burner (they likely have different BTU ratings for different sized burners) and the ignitor post is clean and spaced properly to burner. Then adjust the air mix to achieve a blue flame with just a tip of yellow. Delayed ignition usually results from the wrong air/gas mixture which doesn't ignite until too much fuel has accumulated. In many locations the company you purchase LP gas from will have someone who can check and adjust this. If the range was shipped from the factory as LP gas ready, then you can also contact your dealer and request assistance.
1helpful
Igniter is clicking and won't stop
u have to replace the spark module if only one is sparking. if all spark the check polarity on plug
9helpful
Wolf Range r366 - How do I replace the igniter
I have a Wolf Gas Range and initially my igniter incessantly sparked. I noticed that the igniter is cracked. Do I need to replace it and if so how do I replace it? The electrical wire to the igniter became disconnected; should sticking it back into the igniter cause it to work?
5helpful
2answers
Electric igniters dont shut off
Remember to turn the control knob past the "LITE" setting once the burner fires.
If that is not the issue you have one or more defective spark switches.
Each valve has its own switch wired in series with the others.
How to lift rangetop
You should be able to lift it up actually fairly easy by grabbing onto each corner near front and lifting. Then usually a little prop comes out to set so it stays up and you can clean.
1helpful
Viking range top 2 burners won't light
Either the igniters are at fault (which is usually the case when one or two are not working) or the entire oven ignition system needs to be replaced and can be done through Viking themselves whether you want them to replace it or you yourself replace it, you can get the part through them.
Benjamin
11helpful
3answers
Wolf range cooktop
I just installed a Wolf gas cooktop and had the same problem in that all 4 burners would light just fine but the electronic igniters would not stop clicking on all four. What I found was that the electrical outlet that my gas cooktop was plugged into had the polarity reversed. I tested the outlet with a polarity testing module (you can get one at Home Depot and it checks polarity, grounding, GFI and is handy to have around, small and inexpensive). I plugged it in and the lights told me that the polarity was reversed. I reversed the wires in the outlet (exchanged the white and black wires) put the cover back on, plugged in the cook top and now it works like a champ! no more constant clicking. By the way, we had a cooktop before this one with electronic ignition and never had a problem, apparently it didn't care about the polarity.
Top Wolf Manufacturing Kitchen Ranges Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Wolf Manufacturing Kitchen Range Expert? Answer questions, earn points and help others
