Fix error message
SOURCE: dell inspiron 6000 invalid configuration information
rebooting system fix issues many a times..
SOURCE: my dell laptop latitude d610 have no audio sound
Go to the DELL support page
http://support.euro.dell.com/support
Click drivers & download
enter your system type and model
You will then be presented with all the drivers for your D610.
Download the Sigmatel driver in the Audio section.
Save the file then run to install the driver.
SOURCE: DOWNLOAD OF DELL LATITUDE D610 SOUND DRIVERS
You can download the DELL D610 driver from the link below. You can also download all other drivers and utilities from this link.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WLH&osl=en&catid=&impid=&SystemID=LAT_PNT_PM_D610
SOURCE: invalid configuration information-please run SETUP program
Here is what you do, go into the BIOS setup, usually you press the DEL key OR F2 or whatever your one is, IT should say on screen as it boots up.... it says "Press YOUR- KEY Key for SETUP". So, get into setup, using your manual ensure it is set correctly. Then SAVE SETTING and exit All should be good now.
SOURCE: dell latitude D610. Screen goes black. External Monitor OK.
Make sure you have not accidentally used the FN+F5 key
That combination sets the laptop to use an external display.
If using that does not give you a display take a small torch (flashlight if in USA) and shine it at an angle on the laptop screen.
If you can see any sort of picture you would be looking at replacement of some minor parts to the laptop screen
Hope this gives you the information you need. If not add any extra information you may have and lets see if we can FixYa
Bob
Moderator
It would be very decent of you to consider the quality of our expert’s answers and judge them accordingly as you pass through FixYa.
Thank you
