Xerox WorkCentre XD100 All-In-One Laser Printer Logo
Anonymous Posted on May 28, 2009
I have Xerox XD100. Machine is very noise. The noise is coming from back of machine. Sand like motor is turning but something is stock (can not moveThis motor look like suppose to move)
I have Xerox XD100. Machine is very noise. The noise is coming from back of machine. Sand like motor is turning but something is stock (can not move). This motor look like suppose to move heater part.
Anonymous
Level 3:
President:
  • Master 2,072 Answers
  • Posted on May 28, 2009
Anonymous
Master
Level 3:
President:
Answers
2072
Questions
0
Helped
1109675
Points
5835
There is a small helix gear attached to the shaft of the main drive motor. It cracks or shreads on the inside. You will have to replace the main motor. Not real expensive or difficult to replace.
Xerox Workcentre XD100 not printing
You need to use a IEEE-1284 Compliant parallel cable for this machine. A "changer" will not work, sorry.
2answers
XD100 Won't work with USB
check the usb port boot computer and printer..or parallel to usb or usb to parallell try it..
Xerox workcentre xd100 copier NO POWER
hi,check power cord if the power cord correctly connected the problem is power supply.
2answers
Xerox XD100 does not work
When you saying No working , What Happens when you press the print Button can you manually get this copier to print out ?
Has it stop printing only ?
Xerox copier XD100
Does the machine sit there and run and run and run. The motor turns on and just chugs away or simply the ready light flashes? Let me know which symptom so I can send you some things to try.
XEROX WORKCENTER XD100 NOISE
Most likely the fuser gear is worn. The noise is prominant in the right side toward the back I am assuming.
You can replace the heat roll drive gear itself, but honestly I would recommend replacing the entire fuser assembly. It is probably very very tight and would wear another gear out quickly.
You want to get that replaced before the drive gear on the main motor assembly wears out. It would not rewuire replacing that entire main drive assembly, But it is a real difficult part to replace.
Go onto google and do a search for The Parts Drop. It will be the first item to come up. CLick it on and call and talk to Britt.
He will have what you need for a reasonable price.
if you go that route and need instructions to replace that part. let me know. Its not very difficult.
Xerox xd100 copier
Sounds like 2 different things going on.
The slow warm up is normally the toner cartridge is almost out of ink but not reporting it. It is trying to set up but there is not enough ink to do so.
The jams, if the machine is making it into the machine but not exiting, then you most likely have a broken gear on the end of the heat roller in the fuser
15helpful
3answers
Xerox XD100
I have a XD100 Work Center with a L6 error code indication. After press "C" Clear (orange color button), followed by "Auto" (the most left small button) - exposure mode key; and "C" followed by "Auto" again, the copier starts to print and solved problem.
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
