J Concepts Bar Codes 2.2 1/10 Truck Tire Gold 2 R/C Car & Truck Logo
A
Anonymous Posted on Jan 12, 2014
Ford fiesta 1.4petrol fault code p2176
Car running in limp mode
Just replaced my engine in my 2008 Ford F-250 now truck in limp mode
run the fault codes to find out why
limp modes come from the engine and the transmission so it could be the engine or wires not connected to the transmission
Ford fiesta 09 diesel wont go over 3000 revs,loosing power and slow to pick up speed anh thots please
Its in limp mode,,, need to get code reader on it,
could just be split intercooler pipe, faulty boost sensor or waste gate getting stuck. These all very common
Have a ford fiesta 09,diesel,wont go over 3000 revs,lose power and slow to pick up speed,any thots
2answers
What will cause a 2009 Pontiac g8 gt 6.0 motor to not fire one side of motor
I am reading something all about Limp Mode
or LIMP SAFE MODE...
Which seems to be all about
Thread G8 GT Limp Mode P1516 P2101 P2176
the car being driven at extremes... in other than
prescribed parameters ... causing OBD codes to be posted
My guess you are experiencing Limp Mode
I tried to pull up schematics from Autozone... but your car is not supported Looking for common coil (or coils) fuse(s).
G8 GT Limp Mode - P1516, P2101, P2176
Particularly this last thread [4 cylinder failure]
... but read on
and disconnecting the battery [ ill advised ] to reset the "condition"
Lifter failure or stuck in limp mode or WHAT is going on PLZ HELP LS1TECH
Not Limp Mode
Ford focus 1.6 petrol gone into limp mode what can
run the fault codes to find the sensor that put it in limp mode and repair/ replace it . use that scanner to reset the CPU program to get it out of limp mode.
I have a ford fiesta 2006 diesel manual car , last night when i start my its showa yellow light in the rpm metre and i try to increase the speed but its would not go more than 30kms and my car suddnlt
The light is the engine light and the reason that you cannot go fast is because the CPU is in limp mode. Check the oil and water levels and check engine operating temperature. Have the codes read to find the sensor that put the car in limp mode to protect the engine and gear box.
Astra Mk5 P2176 Fault Code Had a wing replaced on
Firstly i cannot find these fault codes ,either on the generic or the opel code list ,now the computer on this car is on the back of the engine or to the firewall where the servo would be on a LHD model so its possible it got a bit wet ,but without being able to know what the codes are i have no idea where to do from here ,now the only thing i can think off is offside passenger side on a LHD vehicle would mean the gas fume recycling thing is on this side could the body man have left a pipe off this device or cut through one of the pipes ,I do think this is down the bodyshop to sort out for you ,what you should have done was to check the car out first before you paid for it
Top Jconcepts Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Jconcepts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
