I have a hotpoint rf07 fridge freezer,everthing seems to work ok but the fridge collects water inside on the bottom and when you open the door water runs down the side of the freezer door and a pool of water collects on the floor,is this just a case of de-frosting the freezer,if anyone could advice me on what to do this would be gratefully appreciated.
Look in back of fridge and find the drain tube it lets the wter from defrosts trickle into the vaporizer pan in back by the compressor. they pug up. you can clear it with a good wet dry shop vac and good suction on the tube. you should be able to hear suction inside the freezer when you **** it in the back. sometimes these plug up then freeze. you can take interior panels apart in freezer to access or thaw it 48 hours then try the vac. good luck
