The bulb inside the oven popped when the oven was turned on after that happen the oven and the broiler will not heat up the elements are good they have continuity.No codes showing and the burners all working
Do you have voltage? you have to have 240 volts if you only have 120 this might happen check your breaker. does your bake element work? if neither bake or broil work always check the breaker first and let me know
do you have voltage at the heating element? if you do you have a bad element. but sounds like a thermal cutoff blew. check your voltage at the element
never mind you said you have continuity at the elements. find your schematic and look for the, sometimes they call it a thermistate or a thermal cutoff. check your temp probe also you should have 1100 ohms or so. you may have shorted out your computer as well sometimes if you can locate the board you will see a bake and broil relay see if the relays are closeing. you would check voltage straight across without the unit running or trying to run you should have 120 volts when you try to turn on the bake you should have 0 volts. This would mean that the computer is working. definatly locate that thermal cutoff i think it may have 2 orange wires but i am not sure. let me know how it goes
Yes we have 240 volts and the breaker did not trip when the range made the pop sound and the elements stop working.
