How do you remove the grill in front for cleaning without breaking it on GE TFX24RG side by side refridgerator?
Look at the top slots in the grille. If there is a slight cutaway near the ends that is where the release tabs should be. If no release tabs, try a gentle lifting pressure in the grille as you try to pull away. They are made to be removed by the user. Check the manual if you can find it. If no luck, reply, I'll see if I can find one.
Thanks-- I eventually pulled strainght out and the grille came off. It is an old unit, no manual. There is a "male" tab on the grille, and "female" on the refridgerator.
