Changed water filter red light stays on Changed water filter and red light stayed on
Depending on the model of the refrigerator, another thing to try is to hold down the button for 5-10 seconds.
FreshWaterSystems
1.877.335.3339 - http://www.freshwatersystems.com
You will wither have to push the light switch button 5 times or push and hold reset button or 2 at a time. Look at the display carefully it usually will tell you what you need to do
Thank you for your inquiry, John Sodt!
From what you have described your Frigidaire refrigerator's filter display is not changing back to green after the filter has been changed. This could be a miscommunication within the control panel and to clear out any miscommunications I would suggest performing a reset on your refrigerator. The best way to reset your refrigerator is to unplug the power cord for roughly ten minutes. If that does not help your issue you may want to speak with a professional technician. Good luck. -Matt
