The talkabout t5500 and the t5725
Hello bella-9,
The T5500 is a 2 channel radio and the T5725 is a 14 channel radio. However, the radios should be compatible with each other on FRS channels 1-14 as long as both radios are using the same Quiet Talk code. If the Quiet Talk settings are different the radios will not be able to communicate with one another.
Assuming all settings are the same (as you say) and the units are within range of each other (typically less then a mile over clear, level terrain) they should work just fine.
Best Regards,
Ken
"Go Ahead. Use Us."
