Question about New Bright Toys
Rev up not working on harley fat boy
Everything else ok
SOURCE:
Mitchy123
  • 216 Answers
SOURCE: correct torque for rear axle nut on 1997 harley davidson fat boy
Harley manual says 60-65 ft lbs... do NOT exceed this or wheel could seize
Posted on Apr 04, 2009
wd4ity
  • 4565 Answers
SOURCE: fuel gage not working on harley fat boy
The fuel gauge is really two parts. You have a guage and a sending unit. You must have voltage going to the unit as well. On most models, the wires that supply voltage to the gauge run upwards through a small tube in the tank for the bottom of the tank. There is a connector at the bottom of the tank in most cases.
Using a VOM (volt/ohm meter) unplug the connector beneath the tank and check for voltage with the ignition switch on. You should have approx. 12 volts. Once you've finished this test, turn the switch back to the off position.
Next, you will have to check the sending unit. Remove the gauge from it's rubber gasket that holds it in position on the tank. Carefully work the gauge up and out of the rubber sleeve because the wires are very short. Once you have the gauge out, you'll have to check the resistance of the sending unit with the tank nearly full and then again with the tank nearly empty. If the resistance of the sending unit changes, the problem is probably the gauge itself. If the resistance does not change, the problem is more than likely with the sending unit. Check the sending unit for a good ground as well.
The sending unit is held in the tank by five or six small screws. Remove these screws and lift the unit slightly. Do not attempt to remove the sending unit with the fuel tanks full and the bike on the side stand. Fuel will be all the way to the top of the tank and will spill out when you attempt to remove the sending unit. While lifting the unit, turn it working the float arm out of the tank. Be very careful not to bend the float arm. Once you have the unit out of the tank, you can check the unit's resistance again. When you remove the sending unit, always replace the gasket that goes beneath the unit.
Be very careful, you are working with gasoline and expolsive fumes. Do not smoke or have any open flames near.
Posted on Sep 24, 2009
wd4ity
  • 4565 Answers
SOURCE: Want to replace rear brake pads 1995 Harley Fat boy
Replacing the pads on your Fat Boy is not difficult but you need to pay close attention to the way things are put together as you take it apart. Particularly the little steel pad retainers and the anti-rattle spring. These parts are made and go together in such a way that it's very hard to describe how they go in.
To remove the pads, take the two caliper retaining bolts out of the disc brake caliper. These are usually Torx head bolts. Once you get the bolts out, the caliper simply slides to the front and off of the pads. You'll need a way to push the piston back into the caliper so it will go down onto the new pads. I usually do this with a large pair of slip joint pliers. Make sure you put a rag or something on your calipers so you don't damage the piston or the paint.
Now, look at the way the pads, the little steel pieces at each end of the pads and the anti-rattle spring are in the caliper support bracket. Remove the old pads and parts and install the new pads and parts in the same way. Make sure you put the fiber face of the pad TOWARDS THE ROTOR. Don't laugh, I've lots of people put them in backwards, especially on the back side of the rotor.
Now, carefully slide the caliper back down over the pads taking care not to knock the pads out of there positions. I put a little Loctite 242 (med. strength blue) on the threads of the caliper retainer bolts and reinstall them. Torque them to about 25 foot pounds.
Check the brake fluid level in the rear master cylinder and slowly "pump" the rear brake pedal until the rear brake feels firm. Wait a few minutes and mash the brake pedal one time to the bottom. If it goes down to lower point and then on the next "pump" is higher, you probably need to bleed air from the system.
Open the bleeder valve on the caliper, press the rear brake pedal to the bottom and hold it there, close the bleed valve, and then release the brake pedal. Continue to do this until all the air is out of the system and the rear brake pedal feels firm on the first time it's depressed. While doing this, never allow the rear brake fluid reserviour to run out of fluid. If it does, you'll have to start all over with the bleeding process. Use only DOT 5 brake fluid. DOT 5 and DOT 3 or 4 are NOT compatible and will not mix. If they are mixed, it will cause you a lot of trouble in the future.
Test the brakes before you ride the bike and then again when you first ride the bike at a very low speed. Failure to do this job properly can cause serious injury or death. Brakes must operate properly. Good Luck!
Posted on Oct 24, 2009
  • 221 Answers
SOURCE: how do i change the oil on 2004 Harley Fat Boy
on the right side follow the hose at the bottom of oil tank to where it hitches to the frame and on the bottom of frame you will find the drain bolt.
Posted on Mar 28, 2010
wd4ity
  • 4565 Answers
SOURCE: 98 harley davidson rear brake assembly for a fat
The rear brake system consist of a rear brake master cylinder, a metal line that has a tee in it for the rear brake switch, a rubber brake hose and a rear caliper.
I'm not sure what you are wanting to know. The rear brake caliper is held into the rear caliper bracket by two bolts. Remove the bolts and the rear caliper will lift off of the caliper bracket. With the brake caliper off the bracket, notice the position of the pads and especially the stainless steel anti-rattle clips. When you replace the pads and clips, make sure you get them in correctly.
Now, you'll have to compress the piston back into the caliper. To do this use either a large pair of slip joint pliers or a large C-clamp. Use a rag or something to protect the paint on your caliper. Carefully slid the caliper back down over the pads while not disturbing them. Install the two bolts and torque them to 25 foot pounds.
You brake systems, both the front and the rear, take type DOT 5 brake fluid as best as I can remember. Harley has changed the type of brake fluid but I cannot keep up with the year model. It should tell you on the tops of the master cylinder.
Extreme care must be taken whenever working on brakes. Make sure they work properly. Failure to test the brakes for proper operation prior to riding the bike can result in sever injury or death.
Posted on Apr 09, 2010
2003 Harley Davidson FLSTFI Fat Boy starter relay location
Hi, Shane for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can not find the best tool you ever bought for your Harley, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
2003 Harley Davidson FLSTFI Fat Boy starter relay location Google Search
https://www.jpcycles.com/2005-harley-davidson-softail-fat-boy-flstf/starter-relays
99 to 05 Harley Softail Service Manual pdf
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
2005 Harley Davidson Fat Boy Owner Manual
Aug 05, 2018 | 2003 Harley Davidson FLSTFI Fat Boy
Do I need to drain the engine case on my 2002 Fat Boy when changing the oil?
Most people don't bother, because if everything is working right, it'll only have 2-3 tablespoons worth of oil, so it's hardly worth it.
Apr 21, 2013 | 2001 Harley Davidson FLSTF - FLSTFI Fat...
2001 fat boy rear brakes
Hi Anonymous, for more information on your question please visit the websites below and good luck:
How to Change Rear Brake Pads on Harley Street Glide
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 20, 2012 | 2001 Harley Davidson FLSTF - FLSTFI Fat...
Where is alternater located on my 2000 fat boy?
The alternator (rotor and stator) are located inside the primary cover on the left side of the bike. They are behind the compensator sprocket. If the problem is the stator, make sure to replace the four stator bolts. Don't reuse the old ones or they may come loose and cause you more problems.
May 08, 2012 | 2000 Harley Davidson FLSTF Fat boy
Will exhaust from 2003 harley fat boy fit a 1999 harley fat boy
I doubt it. The Fat Boy is a member of the Softail family. In 1999, the Softails were running Evolution engines. They didnt' go to the TC-88B engine until 2000 and that required a frame change. I don't think it will fit but you never really know until you try it.
Steve
Sep 07, 2010 | 2003 Harley Davidson FLSTFI Fat Boy
Revs dont drop
the thottle slide can be sticking, a rich mizture gives similar symtoms
Jul 05, 2010 | 1993 Harley Davidson FLSTF Fat boy
After 70 miles it starts acting like its out of gas
Check that you have a good fuel supply Like floats /needle jets /filters main tank fuel tap and that everything is working ok .
Mar 16, 2010 | 2001 Harley Davidson FLSTF - FLSTFI Fat...
Have a 2004 Fat Boy. Do I need to adjust carburator if I change the exhaust from Screamin Eagle to Cobra Slash Down?
Probably not .... Run it about 100 miles and pull the plugs... if they look OK ( not ash white for too hot or black for too much fuel) you should be OK ....
Apr 18, 2009 | 2004 Harley Davidson FLSTF - FLSTFI Fat...
Toys Logo
19 people viewed this question
Top New Bright Toys Experts
Colin Stickland
Colin Stickland
Jonah Oneal
gerry bissi
Are you a New Bright Toy Expert? Answer questions, earn points and help others
