Press and hold the Mute button on the remote and at the same time press the Enter button on the TV until the Reset menu appears. Press Center button on remote to clear hrs. Your done!
What you need is to have the lamp timer reset. To do so, perform the following;
You will need two hands.
With the remote, press and hold down the "mute" button.
Simultaneously press and hold down the "enter" button on the front of the TV.
After about 5 seconds, a box will appear that shows the total number of hours on the lamp. To reset these hours, press the right arrow button on the remote. After doing so, another box will appear with a confirmation question and an icon for which button on the remote to press to reset the lamp hours.
Any LED light indicators on the screen panel said "LAMP"stay lit or blinking?The projection lamp life is over,require a new lamp,if "LAMP" LED light lite or blinking?The projection lamp in the tv now,been in use for at leat 2 years and tv on about 4 to 5 hours a day?The Lamp life span is over,require a new lamp.
Hold down the mute button on your remote and the
enter button on tv at the same time for a few seconds,
you should get a screen prompt asking if you want to
reset the lamp timer.
Your Tv requires the lamp hours to be re-set. You will need to acess the Service mode settings via a service remote from your authorised LG service agent.
SEDI-POSSIBLY YOUR SET HAS A LOW 5 VOLT POWER SUPPLY.TEST VIA VOLTMETER ON PLUG J-9 WHICH IS ON LITE ENGINE .YOU WILL NEED TO REMOVE BACK OF SET TO MAKE THE TEST.IF 5 VOLT IS LOW BEST TO CALL A MITSUBUSHI TECH.JOE TV
