SOURCE: Broaderbund Version 6 Family Tree Maker
Hi madelyn evan,
Version 6 Family Tree Maker is designed to be used with Windows 95 / 98 , therefore in order to use it in Vista you must run your program using Compatinity Mode --> Install your software--> Go to your Desktop --> Right click on the program icon--> properties-->Compatibility--> select one of the versions above
I hope this helps. If so, please take a moment to accept and rate my solution accordingly
SOURCE: family tree maker platinum 2008
when I open FTM 2008 I get the message that the program was not closed properly and that I should compact the last open file at Tools, Compact file but I cannot go to Tools as the program has not opened. I have tried going to my FTM family file itself but do not see Compact file in this menu. any suggestions. Thanks Claire
SOURCE: I have the Installation programme
Yes, it should run on Windows7, as I have done it some time ago. I have experienced a problem with the some printing options to PDF format, and I need to find a amyuni document converter to overcome this problem. Everythings else works and will not cause any problems to your existing files you have compiled
SOURCE: Is my Family Tree Maker
It is not with Home Premium. You need to upgrade to Windows 7 Professional
SOURCE: I have a broderbund family tree maker version 10
You can read this thread from Fixya.
Hope it helps.
