The caption control is not highlighted in order to turn it off, what can I do?
SOURCE: PROSCAN 32LA25Q
Hey kjr_67,
According to information provided by the manufacturer, you may toggle closed captioning on and off through the "Function" menu. You should be able to reach this menu by doing the following:
1) Press the "Menu" button on your remote control to enter the "Picture" Menu.
2) Press the "Up" or "Down" arrow key until the "Function" menu appears and is highlighted.
3) Press either the "Left" or "Right" arrow key to enter the "Function" menu.
4) Press the "Up" or "Down" button to select "CCD", and the "Left" or "Right" arrow key to change this setting from "On" to "Off".
5) Press the "Menu" button again to exit and save any changes.
If you're still not quite sure how to proceed, I would strongly suggest referring to your owner's manual documentation for further information. You should also be able to find step-by-step instructions with visual aides by visiting the following link to the manufacturer's website:
http://www.oncorpus.com/down/ENG/32LA25Q%20English%20UM.pdf
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
SOURCE: closed captions
In all situations I've seen:
A) It's an option on your cable/satellite box.
B) It's a broadcast signal and it's in the TV menu.
SOURCE: How to activate "closed captioning" for a Proscan Full HD 1080P
Comcast's remote has nothing to do with closed captioning. It's on your tv remote. First, the tv has to be capable of handling closed captioning, and your's is- and second, the program must have closed captioning provided- current programs do, some older shows do not support closed captioning. Recheck your remote, and if necessary- look at the setup instructions that came with the TV- they should also be posted online at the Proscan support site.
SOURCE: Can't get closed caption
Press the menu button on the front panel of the tv or the remote control. Use the up and down arrows to find the features section.Press the right arrow to enter the sub-menu for the features section. Use the up and down arrows to find the closed caption section. Press the right arrow to enter the closed caption sub-menu.Used the up and down arrows and the enter button to go into each of the features, use the right and left arrows to adjust each control for you preferred viewing.Press enter again to select the feature in each of the controls.When you are satisfied with you selections press menu to exit the feature. This information can be found on the PROSCAN website in the customer section under manuals. Go to www.oncorpus.com.the information can be found on pages 21 and 24 of owners manual for your model television.I hope this information helps you with your problem.
SOURCE: how do your turn off the captioning of wat the people are saying on tv off i have a proscan hdtv
hello, just go to the menu and turn it off, normally says CC and gives you a few options including the CC off.
Having same problem...help
I have a Proscan tv. But I have buy me another Proscan remote. So can put close caption on my tv. My man earing impaired.
