Electrical Supplies Logo
A
Anonymous Posted on Jan 12, 2014
Rv onan rv runs but now makes a rackett when running was real quiet
Had started it in cold weather
Renee F
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Onan Expert 573 Answers
  • Posted on Feb 19, 2015
Renee F
Onan Expert
Level 2:
Prodigy:
Answers
573
Questions
0
Helped
248173
Points
680
Contact www.advanced-power-technologies (Cummins Dealer) with exact model and spec number. Also there are cold weather options, and cold weather models. Many people buy the RS units of the net, only to find they have been stuck with warm weather models, and they don't start. Does it show a code, or a code 45.
5 Related Answers
joboo1
Jim London
  • 257 Answers
  • Posted on Mar 02, 2009
SOURCE: onan microlite 4000 generator no output
Hi, The 4000 rv unit unit is equipped with full diagnostics, and is indicated by the status light blinking. The blinking sequence, blinks a code as to the fault. If your unit runs and the status light is on without blinking, it is either the circuit breaker on the genset or in your distribution panel that needs to be reset. Good Luck, this should Fixya!
Anonymous
  • 1489 Answers
  • Posted on Apr 30, 2009
SOURCE: Have an Onan RV generator. WHat kind of oil do I
Standard 30W motor oil.
Anonymous
  • 77 Answers
  • Posted on Aug 10, 2009
SOURCE: onan 4000 start good runs only ten minutsand shuts down,starts up
First locate the oil pressure switch and see if you can bypass it,then see if it runs. If not check the fuel filter and fuel pump,make sure solonoid for fuel pump is kicking on.
Anonymous
  • 26 Answers
  • Posted on Aug 29, 2009
SOURCE: onan genset generator in rv is running but no
on your generator ther is a reset if thats not it check for fuses if still no then u neda check the wires in the pluges if no then ur generator it self needs re bilt
Colin
  • 1584 Answers
  • Posted on Mar 16, 2010
SOURCE: I Onan 5000 genset plus won't start. When I push
Sounds like a flat battery.
2answers
The generator surges and stops while rv is in motion.
Did you get this fixed? this is an old post. If not visit www,advanced-power-technologies.com (Cert Cummins Dealers) They can answer your questions.
2answers
Where is the fuse on the onan 5500 built in generator?
Try under the bench seats around the table, near the heater.
No cold start
Well first of if it cranks slow, make sure the correct battery voltage is being applied. IS the pre-heat function working? If that is not it won't start when cold. Also check oil viscosity is correct. If the pre-heat is working make sure glow plugs are getting warm on each cylinder.
Looking for fuel filter for Onan HDKAK=1046 rv generator. Anyone have the product number
You didn't indicate a Spec number for your gen that would be required. Any RV place can get this part it is Cummins part # 149-2513 but a Spec number would help.
Onan quiet diesel 6000 won't crank clicks
Check battery voltage, starter solenoid, then starter motor
8kw onan genset wont keep running whrn it tries to take on the load, will run forever if i kick the breaker switch to off.
What is the Spec number?
Also can you read a fault code on the start switch?
Do you know how to read the codes and post? if not let me know
Water Heater will not ignite in cold weather. It will start when a manual gas lighter is introduced to the gas tube orifice. In warmer weather it works fine.
What type of RV is this in? If plugged in to hydro , or running off fully charged battery, low voltage shouldn't be a problem, so the solar panel idea makes me think one or the other or both are problems.
1helpful
Our onan generater runs but the power in the rv comes & off,
if ur problem is why does it get loud when the power is off...the answer is GLATOR calibaration..
if u have any further questions email me at [email protected]
3helpful
3answers
RV Onan Emerald 1 Generator
Check all the ground wires and make sure their not broken or loose. If the wires are good next check the neg. Wire to the coil. Too check the swiitch make sure you have continuity too all the post when the switch in the on position, this requires removing the switch.
Top Onan Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Onan Electrical Supply Expert? Answer questions, earn points and help others
