Boston Acoustics Computer Speakers no sound
This speaker system requires a digital audio input, which most older systems don't have. The sound card that was built into your Gateway can put out either a digital or analog signal depending on how you have it set. Chances are your new sound card might be able to output in digital mode as well, but you may have to turn it on manually. Try double-clicking your volume icon in your system tray, then click the "advanced" button at the bottom left. This should bring up a window that lets you adjust the treble and bass, but it should also give you an "other options" area that lets you turn on digital output. If your new card supports digital output, the option should be there. If the card does not support it, you will have to use a different card. I hope this helps.
