Toshiba 55H70 55" Rear Projection Television Logo
A
Anonymous Posted on Jan 11, 2014
Trying to connect ps3 to Toshiba 2181TB without a remote control. None of the 60 channels tune in and can't see a button to switch to av. Any suggestions?
Connected scart to back of tv with PS3 slim but just have a fuzzy screen
2 Related Answers
Anonymous
  • 55 Answers
  • Posted on Dec 26, 2007
SOURCE: tune playstation 3 to toshiba television
first try to manuall select your av channell from your tv's remote control,if this won't work try another scart cable or port on your tv set
AJIN G
Electro Med Services
  • 6694 Answers
  • Posted on Jan 07, 2017
SOURCE: toshiba tv model32w2300A how repair? 0nly in the screen say do not put the power off
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Cant find av channel, remote control is broken
how about the source button in the tv panel does it work so you can get the a.v.
PS3 connected to my TV by Component cables switch to exit2 AV receiver but have no signal
turn onto that channel, then press and hold the ON button untill you hear the beep, it should tune in to your tv
I have a Toshiba W528 VCR and am trying to hook up a Wii in the front panel Line 2 jacks. How do you switch the connnection to the Line 2 jacks without a remote?
With the up and down channel selector buttons. You will have to keep pressing either button till it shows AV (something IE 1 or 2 etc). Depending what it says on the front panel for the socket.
Recommend a universal remote if you can't get a new one.
Channel search on toshiba 27afx54 tv without remote control
Hello
There is no MRNU button on the front panel of your Toshiba TV. So it is impossible to tune it manually. You must have its remote control to select MENU options. OK.
Hi i have an alba tv , im trying to connect a dvd player. I have connected the scart leads etc.I can not get onto the av channel so i can watch a dvd. Please help
Firstly, please make sure you have connected the SCART cable correctly. This should be connected to a SCART OUT socket on the DVD player to one of the SCART IN or EXT sockets on the rear of the TV.
If you have correctly connected the SCART cable the TV should automatically switch to the AV channel when you switch the DVD player power on or insert a disc.
Switch your TV on, then switch the DVD player off and then on again. If the TV does not change to the AV channel you may have the SCART cable connected incorrectly.
Not all TVs automatically switch to the AV channel when the AV device is switched on. On some TVs the AV input is on channel 0 or 99. On other TVs the AV input is not assigned to a specific channel. On these TVs you need to look for a button marked "AV", "INPUT" or "SOURCE" - either on the TV remote or on the buttons on the front of the TV. The easiest way to do this is to insert a disk into the DVD player and start it playing. Then press the "AV" "INPUT" or "SOURCE" button (whichever one you have) repeatedly until you find the signal from the DVD player.
Please check your connections and try using the "AV" "INPUT" or "SOURCE" buttons. If you are still unable to watch your DVD player, please post back with the following information:
1. Model number of the Bush TV
2. Brand and model number of the DVD player
3. If you are using any remote other than the ones supplied with the TV or DVD player, the brand and model number of the remote.
I will then be able to tell you exactly how it should be connected and which buttons (if any) you need to press to access the AV channel.
Hope this helps. Happy New Year!
Regards,
BElectric
FIND AV BUTTON
You can try turning on the video game and changing that tv stations as low as they'll go. sometimes the station will go from 3, 2, aux, side video, av1, av2, etc.. Hopoe the info helps GOD Bless You
Av button not working
you could try connecting the ps2 and see if it will swith to av automatically.usally these telly/dvd units toggle between tv,av,and dvd.if this fails,grab a rf converter unit from a ps1,connect this to the aerial socket and tune it in to a spare channel.guaranteed to work!!!.hope this helps,regards,steve.
Adding a channel to TEAC television
Hi I had the same problem so I bought a cheap universal remote controller and tuned into this model.
Once it is done, press a number on the remote controller and you can start to tune manually.
I do not know about the solution for AV channel.
Tune playstation 3 to toshiba television
2answers
Can't access AV Channel on Sony KV-C27TD
If the TV has no RCA inputs, then there is no "AV channel" option for it on any remote, just channel selection.
The purpose of a RCA to SCART converter (aka RF modulator) is to convert one of your channels to an A/V input. They operate (standard) on either channel 3 or 4 as selected by a switch on the converter.
If your converter is unpowered, it's entirely possible that the signal coming out is not good enough to overpower your antenna signal. In this case, you may need a powered unit (such as this one http://www.bestbuy.com/site/olspage.jsp?skuId=5806345&productCategoryId=abcat0107025&type=product&tab=7&id=1067388827858#productdetail) which can actively "shut off" the antenna input when signal is received from the auxiliary device.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
