Question about Navman Tracker 5500i GPS Receiver
Navman 5500 gps backlight dim but set to max
Backlight on navman 5500 is set to max but hard to see in daylight seems like a bulb is loose it will every once a while get bright
Its water ingress causing a short in the high voltage wiring PCB.
Open the unit with a 1.5mm allen key, unscrew the power/data cable sockets with a spanner and GPS antenna inlet with an 8mm socket (NA to i models) .
Where water has arced there will be burning black on the green PCB evident, cut the PCB wire and remove the section around the burn.
solder a new wire to bypass the short.
Dry the unit and seal with silicone to prevent re occurrence.
Its a 2 hour repair requiring a high DIY soldering standard but off set it against the time it will take to reload you waypoints in a new plotter , its well worth the trouble.
DAKA
Posted on Sep 28, 2011
SOURCE:
Navman Tracker 5500
I am having same trouble. I contacted Navman NSW and went through all the settings without result. It was suggested that the problem could be the external antenna, if not a fault in the machine. I have seen an after market antenna for about $19 so I might try that. It does seem as though the antenna is not talking to the Tracker.
Dec 10, 2012 | Navman Tracker 5500i GPS Receiver
Back light
Most likly the LCD screen is burnt out and will need replaced.
http://www.navman.com/Navman/Templates/standardcontent____3516.aspx
Nov 19, 2007 | Navman ICN550 GPS Receiver
Can not get the back light to light system is working but backlight is not
use a torch to see settings on the screen. if backlight setting is at max. turn off to reset to low then set high. backlight is first to go if battery is getting low.
Jun 12, 2011 | Navman TRACKER 5505 GPS Receiver
Hitachi 50V710 The picture is dim, then the bulb went out. I replaced the bulb. all works but the picture is still dim. You can barely see the screen durring the day. And can only use it in a dark room...
I've seen this in two scenarios.
First: The housing of the bulb is dirty (the lens the bulb lights onto) and the internal screen is dirty also.
The second: The bulb is wired reversely of the proper way to wire it. This will light the bulb, but will not light as bright as when it is wired correctly!
Thank you and please rate!
Apr 08, 2011 | Hitachi Televison & Video
I have a navman 5500i tracker ,the zoom isnt coming up far enough to show water depths and hazards by pushing the + - button .is there an easy fix? Thankyou Muzza
Just got the same one and same problem, I also have a 5505i and is only zooms in close when i put in the c-map chip and it zooms close in the chip area only?? now i have a chip for the 5500i and it zoomed in but only on the Texas part of the map, that is the chip it came with, but i live in Canada. Be carefull the c-map max chip for the 5505i is not compatible with the 5500i it needs c-map nt+ chip. 5500 chip is black 5505 is orange
Jan 19, 2010 | Navman Tracker 5500i GPS Receiver
Display can hardly be seen even with backlight set to max and colour on sunlight
I have the same problem. The backlight in mine has blown. Its a small fluro type globe I we cant buy one anywhere......Any ideas other than nav,an ?
Jul 16, 2009 | Navman Tracker 5600 GPS Receiver
I have a navman 5500,I can hardly see the screen on a sunny day
the problem is that the controlling diode that checks LUX value is damaged (small clear window of minute proportion that adjusts screen brightness)
Jun 29, 2009 | Navman Tracker 5500i GPS Receiver
Picture getting dimmer (?)
Hi, yes it`s time to replace the lamp, and remember to turn maxxed out brightness to normal once you replace the lamp :) good luck, video-tek
Jun 29, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Orbit Media Player DMP 768T - LCD Backlight
I had similar problem and I opened up and replaced the L-shape (usually) back light that I got from other wreck, where the DVD reading lens was not working but the backlight was working. Usually it is not that fairly easy to check any loose wire, bcos there would not be much loose wires. Try, you may be lucky.
Aug 30, 2008 | Audio Players & Recorders
Navman 5500 tracker
Navman 5500 does not support C-MAP MAX maps.. only C-MAP NT+ maps.
Apr 24, 2008 | Navman Tracker 5500i GPS Receiver
Navman Tracker 5500i GPS Receiver Logo
799 people viewed this question
Top Navman GPS Experts
Marvin
Marvin
Jerry Greenberg
Jerry Greenberg
Are you a Navman GPS Expert? Answer questions, earn points and help others
