Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
A
Anonymous Posted on Jan 11, 2014
Akai pt 4299hd projection tv won't focus
We got this tv second hand as is. The picture was really rough. It was green and yellow tinted, kinda washed out and faded. So we pulled it apart and cleaned the lenses and mirror. The green lens has a serious scratch on it, but everything came clean. When we put it back together the picture was really out of focus. Figuring this was because I turned the green lens, I tried to manually correct this but it won't go back to normal. I did try the self focus but it's not fixing the problem. What do I do now?
4 Related Answers
Vista Electronics
  • 1694 Answers
  • Posted on Feb 19, 2008
SOURCE: Akai PT 4299HD picture shift
Sounds like you got it ! Note for the future....if you change
convergence amp IC's...be sure to use top quality name brand
only....no generics ! I use Panasonic with no re-calls.......T.
Anonymous
  • Posted on Mar 23, 2009
SOURCE: Akai PT4298HD Rear Projection Television Problem
My AKAI 42 rear projection self focus set has blue shadows on everything and too much red, I cant seem to adjust it and self focus does not help?
ginstervrt
  • 86 Answers
  • Posted on Aug 06, 2009
SOURCE: very faded.....tv is 7 yrs old....54 in akai projection tv
change the coolant!
tvrepairkits.com can help you find what you need.
Anonymous
  • Posted on Jan 03, 2011
SOURCE: AKAI PROJECTION TV 54" - 6 YEARS OLD, DULL PICTURE
PLEASE BE CAREFUL WHEN DOING THIS PROCESS!!! YOU WILL DESTROY YOUR CIRCUIT BOARD LIKE I DID IF YOU DO NOT TAKE YOUR TIME OR ARE CAREFUL!!
What you need to do is clean the CRT coolant inside the TV. Here is a forum that I SHOULD have read before doing mine:
CRT COOLANT REPLACEMENT AND CLEANING
I was lazy and not taking my time to take care in not dripping any CRT coolant and some got on my circuit board, ( I felt confident since I had changed the Blue CRT 2 years prior) and I was only able to see about 1 hour of the best viewing my TV has ever given me since it was new, it looked like a miracle had happened. My TV was "dull" as the best way to describe it, colors faded, kinda fuzzy. I briefly researched into it again to refresh my memory then jumpted right into not really taking any precautions. I got lazy and didn't take out the CRT's like I did the first time with the Blue CRT and paid the price for it. Let me tell you, theirs nothing worse than getting a perfect brand new like picture only to loose it and hour later because of carelessness. Take out the CRT's, take your time, label everything and take pics, the reward is WELL worth it. Oh ya, you can use Mineral oil instead of the coolant that they sell at stores. Its not conductive, and dose'nt damage the circuit board if u spill a little. I used Baby Oil the first time I did it and when I went back to change the green CRT this time around it was still crystal clear, no discoloration in the Blue CRT I had done 2 years prior. I hope your results come out better than mine did!!
Have a akai tv that's has a green or yellow tint
Hello
Check the picture tube base card for any loose solderings. Your TV lacks Blue colour putput. Check all the solder points on this board. Resolder all the susepected solder terminals [especially take care to blue output section], by applying a little more solder. Check the base connection solder terminals of the blue output transistor. It might be loose, or transistor is defective.
1helpful
I have the Sony KDS- 60A2020 60 inch TV. Recently, my picture has appeared more yellowish. Everyone on it looks like there dark yellowish or have fairly dark (bronze) sun tans. I changed my lamp yesterday...
I have a older 2006 SXRD rear projection TV. I had the same problem after the TV warmed up this yellow tint started in the corner and crawled its way down the TV. It turned out that Sony had a recall on the optic block of the TV. If you replaced the Lamp and adjusted the color this kinda sounds like the same problem. Here is a link explaining it. In this article it shows up as a green haze and blob, but in my TV it manifested as a yellow tint.
http://www.avsforum.com/avs-vb/showthread.php?t=1086180
The color on my Akai PT5499HD projection tv is now showing yellow tint .. help!!
Most likely bad glycol in the blue picture tube (a coolant) and not cost effective to repair.
SD TECH
Out of focus
If it has a convergence function in a menu use that. If that doesn't work I believe your lenses are dirty. Clean them with alcohol and q-tips with the tv on so you can tell when they are clean by the lack of streaks.
3helpful
Double vision w/ red & green tint
This is a comon problem
There are two large convergance chip's
the are failing .Replaceing them will
corect the problem . The chip range
in cost from 16,00-30.00 .There cheap,
so dont let the shop over charge you
for parts when and if you decide to
repair it.
Akai PT 4298hd
aliens... of course
To describe it, it is unaligned kind of like a 3D movie without the glasses. · http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Loss of color picture
I have a blue-ish yellow ghost tint which just appeared on my 51" 51SWX20B made July 2002. Did the magic focus got a number 5 at the end. Did you get a number when you did the magic focus?
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
