Starbucks Saeco Italia Digital Barista Coffee Machine Logo
Anonymous Posted on Oct 21, 2007
Priming problem The unit was off for a few weeks without water in the reservoir. It says it needs priming, but I cannot get it to prime despite repeated attempts.
Cerini Coffee
Level 2:
Sergeant:
  • Starbucks Expert 223 Answers
  • Posted on Nov 03, 2007
Cerini Coffee
Starbucks Expert
Level 2:
Sergeant:
Answers
223
Questions
0
Helped
165736
Points
585
Make sure you try to prime right when the machine is turned on, so that there is no boiler pressure making it more difficult to prime.
Johnny C
Sales & Service
www.CeriniCoffee.com
Edward Harris
Level 2:
Scholar:
New Friend:
  • Expert 78 Answers
  • Posted on Oct 25, 2014
Edward Harris
Expert
Level 2:
Scholar:
New Friend:
Answers
78
Questions
0
Helped
85524
Points
189
Before leaving the machine in storage for extended period, it should be descaled to remove Calcium in the water that is still inside the hydraulic system.
When machine is taken out of storage & used again the pump and hydraulic system is totally dry. A pump is not designed to pump air. It needs priming.
A dry Pump will be louder indication that there is no water in the pump. In most cases flushing some water by turning water knob open will dispense water and machine can be used. When a pump is dry and not able to pump, it becomes necessary to manually feed a few drops of water to bring the pump to function.
Manual priming pump means forcing a few drops of water using a syringe or a Turkey baster. If this is not working, then a more specific pump supplied by Saeco can be used. Link for manual priming instructions is attached.
http://www.partsguru.com/user/Priming%20pump.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 04, 2013
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
3825
Points
Don't buy espresso machines. They don't keep a manual database on line and keep changing models
My unit says prime and no outflow.
"Prime" usually indicates the pump is sucking air. Sometimes the valve in the bottom of the water reservoir gets stiff or gunked up; if you turn off the B60, remove the water container and drip some water into the water intake until it's full, turn the unit back on, replace the water reservoir and that little amount of extra water should be enough to allow the pump to work properly.
1helpful
When power is turned on the word prime appears in the LCD control center screen and the water low lights flash in the water reservoir but reservoir is full What is wrong?
the word prime means that you have to fill the unit first so that all air is removed
check for some sort of bleed valve /screw at the top
fill the unit first then connect it all up
all these sort of instructions will be in the user manual for you to follow
7helpful
4answers
What does "prime" mean and
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
64helpful
2answers
Prime appears in the window of my Keurig. How do I get air out of the line
heatman101
3helpful
2answers
I keep getting "prime" after every cup of coffee;
heatman101
2answers
My Keurig coffee maker is not brewing. The word prime is on the screen. How do I prime the unit.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jul 14, 2011 • Vacuums
2answers
Am unable to prime water pump
Water is not being drawn from reservoir into boiler. The valve at the base of the boiler seems to function properly. After repeated attempts, I am unable to prime pump and fill boiler with water.
3answers
Can't prime new machine
brand new machine you put water in the container prime it with turkey blast open the valve on the side off machine and it still does not work tank good for warranty cheers
Top Starbucks Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
