The countdown clock is very slow. Says 25 minutes remaining for last 4-5 hours. Machine seems like it is about to start, then stops and restarts. Service call was made and they found no issue. Intermittent problem.
SOURCE: whirlpool calypso washing machine
Could you possibly supply a model number and serial number. This will help greatly in determining the cause of your problem.
SOURCE: whirlpool calypso washer
Code LS=Lid Switch. I had the same problem and found that if you pressed down firmly on the lid when closing I would not get the LS code. An uneven load will sometimes cause enough vibration to the lid to stop the washer and display the LS code again. Just lift lid and press down firmly again and start. Eventually I will open it up and adjust the switch.
Buy a new machine. We purchased ours from Sears 4 years ago, thank goodness we purchased the extended warranty, as Sears has been out numerous times to repair. In January 08, Sears replaced the pump only after they forced us to sign a waiver before they would even touch it, because my washing machine sits in a drain pan and they didn't install the drain pan. We signed the waiver (I need my washer) and the tech destroyed the drain pan and my my floor, basically she forced me to give her permission to do so. February 08 the extended warranty expired, June 08 the pump quit working again and Sears only warrantys part replacement for 90 days. BTW - the previous Whirlpool calypso model and Kenmore had a class action suit against them. Sounds like the newer models owners should do the same. Sears techs even told us to get rid of it. We bought a new one from Home Depot...
SOURCE: Whirlpool Calypso stops at 26 minutes and throws ob code
first you need to clean your washer
run the washer with no clothes; add 1 cup vinegar, that will cut the soap residue from the hoses do this on hot wash hot rinse
then when you wash your next load of clothes; fill the tub about 1/4 full, add the soap, turn the agitator to disolve the soap, then add the clothes
this problem happens also if you are using too much soap or a heavy duty soap such as Tide.
SOURCE: I have a Whirlpool Calypso washing machine, model
communication error. changing the MCU. sometimes a bad pump could be the problem
