SOURCE: Have Miele G653 SCVi plus. We have inlet/drain flashing red light
Sounds like something is caught in th drain pump as the unit has to drain first before anything else happens. Remove the filter and the non return valve which is under the clip in the sump of the unit. In the manual it shows you this. Make sure the drain pump is free of any foreign particles like broken glass. Then start the unit again so it goes to drain without the non return valve in place. This will then throw out any foreign particles as well.
or it could be the drain pump is activated all the time which is the noise you hear as there is a flood in the base of the unit which activates the float switch and constantly activates the drain pump until the water has gone. Isolate the unit at the power switch and remove the bottom panel under the door panel. Dry up the water as best possible with a towel. You will see the float at the front. Run the unit again and check for any water leaks. You may just have over sudded the unit with too much detergent. Only use 2 teaspoons of powder. To start with while testing don't use any detergent. Good luck
Testimonial: "Thank you for your excellent advice, the machine was flooded in the base when the panel was removed. "
SOURCE: Miele model G653 SCVi Plus-3 Dishwasher
Hello &
Welcome to FixYa The first
thing that should be checked is the drain hose and the drain pump operation, if
the drain hose is clean then check the drain pump, if its not working then
replacing it is recommended. Then check the water inlet valve and make sure it
is not clogged and the water is coming inside the unit. After cleaning both
pump and inlet, unplug the unit and plug it back after 15 minutes so that it
works again. Please get back to me if you have any other questions. Kevin
there is a piece of debris in the drain pump. remove the triple filter from the bottom ( the one you are supposed to clean every week to keep debris out of the drain pump) under that filter and to the left hand side you will see the non return valve. squeeze the tab and pull the non return valve out. remove the broken glass or whatever is stuck in the drain pump impeller. replace the non return valve. replace the filter. if you need a picture go to mieleusa.com, and search for your owners manual. it has step by step tutorials on how to free an obstruction from your drain pump.
SOURCE: Miele G1182 dishwasher not working
Any water comming in to the dish washer area?? If not check the inlet water valve, they get clogged with sand from the water supply. They can also clog open, in which case the dishwasher will flood the floor with water afer about 3 to 4 imins of use.
