Three major components usually is causing this kind of problem. One is the memory card. Two the video card . and lastly worst is the motherboard. Check and clean your memory card first then put it back to its place of slot. Start your computer. If you hear one beep but still no pictures, the problem lies in your video card. If there's still no beep sound and picture, and you think your memory card is good, try to clean your video card, then start your computer. If there is still no picture, and you think your video card is good, then you have a problem with your motherboard. Indication that your cpu is working were, beeping sounds, lead lights blinking or changing sequence is present. If it is present, your monitor has a defect an needs to be replaced.But if none of this is present, we have a motherboard problem.
Remove the memory (RAM). Clean its contact points by an eraser. Fix it. If it does not work, try using another slot. If it still does not work,replace it with new.
Plug in power cord, remove key, hold down speed+ and stop buttons,
replace key, release buttons, press stop once, press and hold speed +
until max. treadmill will run to top speed (s9.80 should read out 11.8
to 12.5.) It took a couple of times to get this to work for mine, but
now it is OK. If unit does not run after several attempts then the
console is probably bad and will need to be replaced ($410). Get
another treadmill ! If it does run the console may still beep -
problem is with IFIT card. You can get rid of the beeps by opening the
console and unplugging the IFIT cable from the computer card if you
want.
See if there is an error beep. If there is an erro beep, then change main board. Power off. Then check if RAM CPU BIOS are well-connected. Press Fn+F5 three times slowly LCD FPC LCD inverter LCD USB does not work correctly USB device cable is firmly connected into the USB ports. Test
check the new memory in all memory slot that u have. use thinner with a art paint brush just past it in the memory slots, just like cleaning them up. then place the memory about some seconds. switch it on. if doesnt work see your graphic card. or try a kingston memory. kingston memory works on almost all motherboard. some others even new, they dont work on some motherboard.
turn it off and then hold the power button until you here three beeps(not including the first power on beep).A menu should open,choose 2, this will reset your video settings.If it does'nt work first time do it again.
