It is rarely ever legal to share license keys even with your own
immediate family members for any software or online service. The only
keys that are "legal" to share are those for trial versions etc that are
licensed for free distribution anyway. Sharing keys for software/online
services such as Ultra MP3 (including the mobile version) is the
equivalent of pirating, because you obtained such information without
paying for it - which is the whole point of having license keys: to be
able to use such software or online service and prove that you did
purchase it.
Where Is Your Serial Number
The serial number would either be on the back of the CD case or within
the documentation that came with your software when you purchased it.
You will know it is the serial number because it is a mix of numbers
and/or letters separated by dashes, usually around 20 characters long.
Install Without Serial Number
You can't install this software without the serial number. Follow the on
screen instructions during installation. One of the instructions will
come up asking you to enter the serial number - put it into the white
boxes - and the installation will continue. You can't use the software
without installing it.
What To Do If You've Lost Yours
Contact costumer services at Norton (by mail, email, or phone). They
will probably need proof of purchase such as original receipt, bar code
on package, or some other form of identification. They will instruct you
on what is needed and will then give you a new serial number if
necessary.
More Info
Downloading proprietary software is illegal (except for trials). This is
called piracy. Using serial numbers that you did not purchase is also
illegal, even if you purchased the software and lost your serial number
(see above for obtaining a new one in this case). It is also illegal to
use key generators (keygens) which provide serial numbers as well as
cracks to bypass expired time trials or entering a serial number and
no-CD cracks which enable you to use the software without the original
purchased CD for the software.
WikiAnswers will not provide serial numbers or links to serial numbers.
We will also not provide information or links on where to obtain pirated
software, serial numbers, keygens, or cracks. If you are caught doing
any of these, you may be blocked from using WikiAnswers as well as
reported to the proper officials and/or the company who created the
software.
Note: This is a catch-all question. Neither it nor its
alternatives should be deleted or removed. It should also remain
protected so that illegal information cannot be posted.
did you contact to Sony ?
