Question about Pride Celebrity X 4-Wheel Electric Scooter
Battery fully charged but not power to run
The scooter says fully charged but the scooter does not run
  • Pride Master
  • 10,543 Answers
Measure the battery voltage individually. If each battery has less than 10 volts, charge them with an automotive style NON automatic battery charger.
Posted on Sep 03, 2017
SOURCE:
  • 118 Answers
SOURCE: New batteries, fully charged, still wont work
I have the book if you can figure a way to post you email without getting too much SPAM. Be sure the charger is un-plugged, and that the free wheel lever is engaged.
Posted on Nov 27, 2008
SOURCE: pride victory Scooter battery charged won't run
Its probably too late to give my opinion, but here goes anyway.
I had a similar problem with my mothers scooter and it turned out to be a faulty connection on the wires leading to the motor. I simply pulled the plastic connection apart, cleaned and lubricated the contacts, refitted the connection and all was well.
Posted on May 13, 2009
gewiz
  • 1367 Answers
SOURCE: Battery fully charged, buzzing sound when i try to
check the FREEWHEEL LEVER at the rear of buggy to make sure it in the drive position, if you can push the buggy it not in drive mode.
Posted on Jun 13, 2009
  • 61 Answers
SOURCE: My Pride scooter is fully charged but there isn't
Does the battery meter move and does the green LED on the console come on? If not, then this would probably be the circuit breaker has popped or possibly a fuse blown somewhere. There may be a fuse on each of the battery harness leads, so they could be worth a check. May also be a bad connection somewhere or a broken wire. Also worth checking the key switch incase this is not working. If the green LED on the console IS on, is it flashing and if so, how many times. This is a built in diagnostic system and will tell you what is wrong with the scooter if you have the owners manual to refer to. Hope this helps...
Posted on Mar 19, 2010
Testimonial: "Thanks for your help. One of the connection from the battery was burnt"
rulds2008
  • 3866 Answers
SOURCE: My sonic disability scooter's battery is fully
Most of the scooters expeinece a bad control board, this control board is where you steer and power on your chair. This is a costly repair and would need certification because its a mobility device. I recommend you have it repaired locally instead of taking advice on the web as the issue could be something simple, because I worked on my dad's device I thought I would give you a hint of what it could be.
I would appreciate if you leave positive feedback before you leave please.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Sep 26, 2011
Is it best to keep my scooter on charge all the time or what
Lead acid or deep cycle gel batteries are best kept on trickle charge.
Take care of your batteries
How do I get the most life out of my new batteries?
To maximise the life of your batteries, it is best to complete a full charge for the first 1015 times that you use your scooter. This simply means however far you travel, do not just top-up for a short while, but complete the full charge cycle every time. Your batteries will not work at their best until this process has been carried out and will prolong power and performance. You will find the distance your scooter can travel will gradually increase over its first few weeks as your batteries reach optimum efficiency.
When is it best to charge my batteries?
After 10-15 cycles have been completed, a normal charging routine can be adopted
  • Depending on the capacity of the batteries, the charge time can vary up to a maximum of 16 hours
  • The charger will automatically shut down when the batteries are fully charged, so you do not have to worry about switching it off. This is ideal for overnight charging.
  • Whenever possible try to avoid interrupting a charge cycle. It is always best to complete a full charge cycle as excessive short term charging is detrimental to battery life.
  • For the very best results and to maximise battery life, charge fully before and after use.
  • Please refer to charger indicator lights for battery status.
How do I store and maintain my batteries?
  • If your scooter will not be used for a while or is being stored, make sure the batteries are fully charged first.
  • If your scooter is not being used, make sure the batteries receive a refresher charge every 14 weeks. Alternatively if you are planning not to use your scooter for over 6 weeks, fully charge your batteries and then disconnect.
  • Fully charge the batteries before re-use.
  • Never leave the batteries in a discharged state.
  • Avoid damp, hot or cold extremes when storing your scooter.
  • Batteries are totally sealed and do not require any maintenance apart from charging.
Charging
1.Switch off your scooter and remove key.
2.Plug charger into scooter charge socket.
3.Push charger plug into wall socket and switch socket on.
4.There will be a light sequence on the charger but as all chargers are different, refer to charger instructions.
5.Most scooters will have an inhibit mode which will shut down all the scooters electrics while the charger is plugged in.
6.Only use the charger supplied with your scooter.
7.Do not smoke or use a ***** flame while batteries are being charged.
8.Do not leave charger plugged into your scooter when the charger is switched off as this may discharge your batteries.
9.For a complete charge do not switch off, unplug or interrupt the charge cycle until it is complete.
It is worth considering that in extreme cold weather the time your batteries take to charge can increase by up to 20%. The range of your scooter will also vary based on weather conditions. Also when your batteries reach the end of their useful life, you will find that charging time will become much shorter. The amount of charge the batteries can hold will become less and less as will your scooter range until ultimately they become unusable.
Mobility Scooter Battery Charging - CCF Mobility
https://ccfmobility.co.uk/2009/09/29/mobility-scooter-faq-battery-charging/
  1. Cached
  2. Similar
Sep 29, 2009 - A: Charge it over night after each time you use the Mobility Scooter using ... Q: If I leave my Mobility Scooter on charge for a day or more, can it ...
E-Bike Battery Maintenance 101 - Durham E-Bikes
https://www.durhamebikes.ca/ebike-battery-maintenance-101
  1. Cached
E-Bicycle/E-Scooter Sales & Service Retail Facility ... It is best to keep your batteries charged up as much as possible. Just remember that charging time will correspond with how discharged your batteries are, and you will ... Our fixed battery bikes are all equipped with sealed gel lead acid batteries and should not freeze up ...
Proper Charging for Scooter & Wheelchair Batteries - ezMobilityBattery
https://www.ezmobilitybattery.com/wheelchair-battery-charger-answers
  1. Cached
  2. Similar
Power / Electric Wheelchair and Mobility Scooter Battery and Charging Questions ... Wheelchairs and Scooters you can leave the charger plugged in all the time. ... Remember, if storing your chair for longer than a couple of weeks, it's best to ...
SpinLife Guilde to Mobility Scooter Battery Maintenance
https://www.spinlife.com/en/mobility-scooter-battery-maintenance.cfm
  1. Cached
That's why it also is a good idea to keep an extra, fully charged battery on hand in ... If you use your mobility scooter every day, get in the habit of charging its ...
SCOOT AND BE SEEN keep your scooter in tip top shape
Jun 13, 2018 | The Health & Beauty
MY QUESTION IS ABOUT BATTERY POWERED ELECTRIC SCOOTERS. WHY IS IT THAT i AM NOT GETTING NOWHERE NEAR THE RANGE that I am getting from a fully charge scooter.
Sounds like either the battery or charger is not working properly. If the machine has been sitting around for a long time without charging the battery then the battery may not hold a full charge, I would pull the batteries and have them checked out and see if they are charging up to snuff. Fully charge them before you get them tested. There should be no charge to check them.
Oct 03, 2017 | Electric Health & Beauty
My scooter will not fully charge
This could be the charger socket is worn and not making a good connection when charging or it could be the charger itself at fault. Now you have changed the batteries, I presume new and both the same type, you need to look at the charging side.
Apr 03, 2013 | Rascal 600 T Electric Scooter w Seat Lift...
Why won't a scooter with a fully charged battery
sounds like your motor is burned out take it off and have it checked
Apr 28, 2012 | Health & Beauty
Battery charger indicating that batteries are fully charged, but battery meter on the scooter shows no power at all. also the lights, indicaters etc arent working, im presuming that is resulting from the...
With a Pride Scooter the charger will turn green if its fully charged and if there is a bad connection in the wiring with the batteries. If you plug in the charger and the light comes on green right away then there is a problem with the wiring or connections. Take a voltmeter and read the voltage at each battery. Fully charged they should be 13-15 volts each. If they are less than 12 volts then they are not charged and the charger is not working correctly. If the batteries are really low like less than 8 volts each then the scooter might not come on at all. If you find that the batteries have at least 12 volts or more then there is a wiring problem from the rear of the scooter to the front tiller. Pride has a habit of developing problems in the harness running from the rear to the tiller. My suggestion is to contact your provider (where you got the scooter) and have them troubleshoot the scooter. If the scooter is less than a year old then it should be under warranty and your provider will have to fix it under warranty. Sorry I don't have a quick fix for you but scooters are notoriously bad to troubleshoot and repair, especially long distance. Hope this helps you
Mar 14, 2011 | Pride New Mobility Victory XL 4 Wheel...
MY scooter battery needs recharged and I plugged it in and it indicatied it was fully charged and it wasnt. So I bought a new charger and that is showing the same thing. I dont know what to do next. The...
Has the scooter been stored unused for a while? If so, the batteries may have gone solid from improper maintenance. There is a gel inside the batteries that needs to have current run through it at least once a week to keep them fluid. The charger is showing a green light because it senses the batteries are full, but instead of being full of power, they are full of crud and need to be replaced again. If the batteries have been properly charged but you still cannot get power, check all your connections to make sure they are tight and that your fuses are not blown.
Oct 12, 2010 | Electric Mobility Health & Beauty
How to charge my panterra transport scooter,do i leave switch on or off and for how long?
tony you can charge it either way with switch on or off and if you have used the scooter alot during the day and the battery level lights are in the red charge overnight. The charger light will turn from yellow to green when the batteries are fully charged It really is a good idea to get into the habit of charging overnight wehn you have used the scooter all day. It helps the batteries to recycle them thru a charge cycle when they run down. Now if the scooter is used rarely then make sure it is fully charged when it stored and charge once a week when idle. Hope this helps you
Sep 09, 2010 | Health & Beauty
Battery is charged, however there seems to be more power
Yes a charge fresh, fully charged battery will allow for the scooter to perform at it's peak top speed. Also fresh, fully charged battery will read more than 24v on a voltage meter and this is ok.
Aug 13, 2010 | Razor E100 Electric Scooter
Shop rider sovereign voltage indication. Brand new fully charged
hi Richard,
Does the scooter actually lose power after the 3 leds show ?
If it is losing power then a suggest to try some other batteries to confirm dodgy batteries, check the terminal connections etc.
If it does not lose power then the volt meter is at fault, if you can check the voltage before riding then after it shows only 3 leds , if there is a big drop, check the charger first to make sure the batteries are getting fully charged.
Regards
GeWiz.,
Dec 21, 2009 | Electric Mobility Shoprider Electric Power...
Shoprider cadiz scooter, batteries show full charge when first charged up but when driving scooter battery power runs out after about 3 miles. brakes work fine, no noises from motor or gearbox, what's...
I think your batteries haven`t been charged properly,or they have been left standing so the charge has leaked out.At a minimum your batteries need to be charged for 12 hrs a day for the first month if not they will not build the capacity and will dwindle and die for example it is at only 25% capacity,but looks like a fullcharge, it says it fully charged but will die
quickly this happens because it is charged to its full capacity but that is only 25% of the batteries true potential
resulting in short battery life.
Unfortunately majority of scooter batteries like this have to be newly replaced.
Nov 06, 2009 | Health & Beauty
Pride Celebrity X 4-Wheel Electric Scooter  Logo
69 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
