Happens even with volume down low -- works fine at times and others you have to turn it off immediately due to the static problem -- connected to Bose Acoustimass 10 system
SOURCE: Denon AVR 2807 with Bose Acoustimass 15
Well,i can tell you are not very focus,cause you posted Denon AVR-2807 with Bose AC 15 problem,but under your details,you put down AVR-5807!
First of all,it is so unfortunate that you are NOT able to gain and experience to true ability in sound for this wonderful receiver when you are using a dual tweeters speakers and expect to have good sound separation as a TWO WAY speakers(a tweeter and a midrange-for true high frequency and mid frequency sound separation.)
Secondly,you have defeated the audio configuration of the Denon AVR-2807,since all your speakers are control BY the Bose subwoofer.
Now,i could show you a way to hook this up,and it doesn't matter how you connect them, they are the "bicycle tires" installed with a "Porche"engine if you know what i mean.
If you want a good recommendation for your "beast",i will more than happy to show you the way!
Cheers,
solutiondoct
SOURCE: I am getting static out of all speakers in my
Static could mean a few things.
Magnets on or near (tube TV's) the system could disrupt the signal.
Try plugging the speakers in one at a time with music going to the AUX in. Run through all your settings to make sure that nothing is abnormal.
If it's plugged into a powerstrip, try plugging it into your wall outlet.
201-762-6500 is their main number.
SOURCE: Denon avr-1804/884, speakers Bose vcs center, Bose
You don't say how "TV audio" is entering the system.
My guess is you're using analog audio Out from the TV into an analog input on the Denon. One channel failing would probably be the Left Channel cable failing or not seated.
I always recommend bypassing the TV audio entirely if the programming comes from somewhere other than its own antenna, as TV audio electronics add nothing good to the process.
If you're using cable box, sat box, game, whatever, ITS audio is best sent directly to your Denon's specialized audio hardware - digitally, if possible, to preserve multichannel possibilities.
You could also run standard analog audio from the cable box to the TV analog Audio IN if you just want to watch news and weather on TV speakers without the Denon involved.
SOURCE: Denon AVR 591
This is where a circuit diagram would come in handy, displays are tricky to trouble shoot, and this a job for a pro.
Register and download the manual for free audio.manualsonline.com
http://audio.manualsonline.com/manuals/mfg/denon/avr591.html
Disassembling the parts of HTS and reassigning them to other makes and models is unwise and unpredictable electrically and sound-wise.
