Whirlpool WRX735SDBM 25 cu. ft. French Door Refrigerator With Logo
A
Anonymous Posted on Jan 11, 2014
Icemaker stopped making ice after replacing filter with bypass
I forgot to purge the line after replacing the filter with bypass and icemaker stopped making ice. Icemaker seems to be working properly as it is running, so I think maybe the water line is frozen where it releases into the icemaker. I've tried thawing it with a hairdryer with the fridge unplugged. I got it fairly warm in there with the fridge unplugged, plugged it back in and noticed that the water line that is exposed on top of the fridge filled back with water (there was an air pocket in the line when I started). Do you think I did not thaw it long enough? Can you provide feedback regarding removing the icemaker to physically clear the line? Please advise. Thank you.
5 Related Answers
Anonymous
  • 8619 Answers
  • Posted on Apr 05, 2009
SOURCE: Thin Ice on Whirpool Ice Maker
Hi
If  The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
Anonymous
  • 47 Answers
  • Posted on Nov 11, 2009
SOURCE: my icemaker quit making ice its a whirlpool ref.
i could bet my left leg that your solenoid coil has died. im guessing its still pumping water and getting cold.
Anonymous
  • 401 Answers
  • Posted on Feb 14, 2010
SOURCE: ice builup on back wall of top mount whirlpool freezer
It sounds like it is not defrosting. Could be the heater, terminator, or the defrost timer. There is still ice built up behind the wall and won't take long for it to stop working again.
Anonymous
  • 11 Answers
  • Posted on Apr 02, 2010
SOURCE: Freezer stopped working.
It might be the compressor making the noise.If it is,the compressor will start/stop frequently.This means that it is tripping on overload due to mechanical damage.Only way to solve this prolem is to replace the compressor (if the freezer is still in a good condition).
Regards
Andre Nagel
Anonymous
  • 523 Answers
  • Posted on May 05, 2010
SOURCE: defrost timer side by side was replaced freezer
check your drain in the freezer
Not making enough ice
Thank you for your inquiry, Herb!
I see that your Frigidaire refrigerator, FGHB2866PF, is not making enough ice. When is the last time you changed your filter? It is recommended to change your filter every six to nine months. If the filter is dirty the icemaker will not produce. You may also have a frozen water line and you can perform a manual defrost in order to clear out the line. To manually defrost your line you would need to disconnect power from it for at least three to four hours. If that does not correct your issue you may need to have a professional technician out to perform a diagnosis and repair. I hope this information is helpful. -Matt
Ice maker don't work
They are usually located behind the compressor compartment panel. remove the panel and follow the water line you should see the water valve. If there is a water filter in your unit these can plug up ,and cause no water to enter the icemaker. I alo have had bad icemakers.
1helpful
Have viking side by side referagator , freezer model # ddrb304. I installed copper line to ice maker yesterday It is not making ice. Checked that water supply is on. Appreciate any suggestions Lou
make sure you have strong water pressure to the frig.
Do the ice maker have a shutoff arm? or a shutoff switch? either way make sure it is on. by now there should be water in the icemaker tray. if not then manually pour 1/2 cup of water into the icemaker. if it does make ice then replace the water fill valve.
if there is ice still in the ice maker tray you still have to check the water fill valve before we can say the icemaker doesn't work.
need a meter to check the continunity of the water vavle. if the valve is open repalce valve, if there is continunity the the valve is good.
hope this is helpful. if you cant do this ask a friend who is an electrician to help you
Mar 27, 2010 • Freezers
1helpful
Icemaker makes shells. Outside is frozen but
Hollow cubes are caused by not having enough water in the ice mold. Fill it up manually by pouring water in it and see how the cubes turn out.
look for an adjustment behind the plastic endcover with a +/- on it. - is less water. + is more water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
There is a screen filter before the water inlet valve in the water line. It can get partially stopped up with sediment blocking water flow.
Oct 28, 2009 • Freezers
Icemaker will not STOP making ice
check the sensor that tells the machine to stop harvesting.
Jun 30, 2009 • Freezers
The icemaker in my Bauknecht KGN 7010 F/F has stopped making ice
First you need to find out if the lie is blocked. Disconnected water feed and try to run water through it into a bucket or sink. If you get water it is a valving problem. Also make sure the filter is clear.
Dec 29, 2008 • Freezers
Items in freezer melting, Ice maker empty, fridge feeling warm
hi there,
you have 2 problems:
frist check the freezer thermostat and make sure that it's set to at least 5 or 6. if that is okay and you still have this problem, you may need to have the thermostat replaced and maybe more.
as far as the icemaker, if it's just the ice part that does not work, i would recommend checking the valve and water line coming into the icemaker.
can you tell me if this is a side by side or a top or bottom mount freezer? if you have the model #, that would be great.
Icemaker
You might have a frozen line. Also and this seems more important to you its prob to cold, Trust me to cold of a refrig will cause hollow ice cubes first leading to a frozen line. Clean your coils, if you have another refrig empty out into that, unplug it leave doors open a couple days. If you can get to water line use a hair dryer from a distance defrost line, turn down freezer half knotch 1 full one at maximum. should fix issues, especially if filter already changed. If this all check prob a clogged line, not just frozen.
Ice maker is not getting water.
check and reset the temp in the ice maker freezer coils them self's
Top Whirlpool Freezers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
