the code is P0209. They are giving you the gears. Nothing to do with Catalytic converter which is between $210 and $400 to replace. Cat is P0420 code. All these codes can be found on Google
What the P0209 code means. The meaning of the P0209 code is that the fuel injector circuit was found to have out of range voltage or resistance. This out of range performance is detected by the Engine Control Module (ECM) and this causes the Check Engine Light to be triggered.
Engine Control Module (ECM) checks the injectors circuit resistance and monitors the voltage drop during normal operation. The ECM will trigger the P0209 code ...
OBD code P0209 is defined as Cylinder 9 Injector Circuit Malfunction. This error code is set by the PCM/ECM if it detects low or high voltage drop or resistance ...
P0209 Dodge OBD Error Code: P0209 Lincoln ...
P0209 Chevrolet OBD Error Code: P0209 Kia ...
P0209 BMW OBD Error Code: P0209 Infiniti O...
P0209 Acura OBD Error Code: P0209 Honda ...
Cat cost, plus an hour to fit https://www.rockauto.com/en/catalog/chevrolet,2012,traverse,3.6l+v6,1501884,exhaust+&+emission,catalytic+converter,5808
that is a dash code, right and not a real scan tool.
read the FSM. it all there.
or go to alldata.com (might be there and is for real DTCs )
or google it.
let me guess, the check engine light is glowing driving
and you ignore that?
scan it , and see all errors. and this
fault Code: P0780(4501);
P07xx are tranny errors.
reset the ecu (scan tool button) and pray it dont come back.
P0733 indicates which gear has a gear ratio that varies from
the correct gear ratio, the corresponding in-gear trouble code ranges
from DTCs P0731-36.
Without taking apart the transmission and inspecting for damage, it is
difficult to say what the exact problem is, but many people who get the P0733 code have fixed the problem by replacing the
accumulator in the transmission.
code P2101 (which is a Throttle Actuator Control Motor)
Trouble Code: P2118 Electronic Throttle Control Motor Circuit Malfunction
Trouble Code Conditions:Ignition is on and ETC motor is not in limp-home
mode. When the PCM detects an internal error or short between the ETC
motor and ETC motor positive circuits in the ETC motor driver. The ETC
light will be flashing.
Possible Causes:
Throttle plate or bore malfunctions
ETC positive circuit is open or is shorted to ground, battery voltage or ETC negative circuit
ETC negative circuit is open or is shorted to ground or to battery voltage
