TP-LINK TL-WR1043ND Router Logo
A
Anonymous Posted on Jan 13, 2014
Td-w8970 turn off nat - TP-LINK TL-WR1043ND Router
Error 49 in HP LaserJet 100 color mfp m175a
HP printer error 49:
Error [b][i][u]49[/u][/i][/b] is [b]'Firmware Error'[/b].
[i]Firmware[/i] is the built-in software on the printer's electronics.
In layman's language, your printer's brain has become confused.
Here are several steps you can try, to hopefully clear the error:
[table]
[tr]
[th]01:[/th]
[th]Cancel Print Job[/th]
[th][b]Cancel[/b] via printer menu [i]and[/i] via Windows' Control Panel, to make sure.[/th]
[/tr]
[tr]
02:[/td]
Turn Printer Off[/td]
Power it [b]OFF[/b], then [b]ON[/b] again.[/td]
[/tr]
[tr]
03:[/td]
tESTING..[/td]
Try reprinting, to [b]test[/b] if [b]error[/b] has [b]gone[/b].[/td]
[/tr]
[tr]
04:[/td]
Try Different App[/td]
In case the [i]application[/i] is [b]corrupt[/b] or non-compatible, try printing from [i]other software program[/i].[/td]
[/tr]
[tr]
05:[/td]
Try Different File[/td]
In case the [i]file[/i] is [b]corrupt[/b] or non-compatible, go back to your [i]original application[/i] and try printing another file.[/td]
[/tr]
[tr]
06:[/td]
Upgrade Driver[/td]
If you find that [i]only certain files or apps cause problems[/i], [b]upgrade[/b] the printer driver to the latest version.[/td]
[/tr]
[tr]
07:[/td]
Upgrade Firmware[/td]
If the driver upgrade does not give you any joy, a [b]firmware upgrade[/b] may be necessary.[/td]
[/tr]
[tr]
08:[/td]
Refresh Entire System[/td]
Failing all of the above, an entire refresh / reboot may be necessary:[/td]
[/tr]
[tr]
09:[/td]
Freshen Up[/td]
Turn printer [b]OFF[/b]. Pull all printer-connected cables [b]OUT[/b]. In Win Control Panel / Devices, [b]DELETE[/b] Print-Queue. Switch [b]OFF[/b] computer. [b]REBOOT[/b] computer and printer. [b]RECONNECT[/b] cables. Try [b]PRINT[/b] again.[/td]
[/tr]
[tr]
10:[/td]
Clean Computer Registry[/td]
In addition to the 'Freshen Up' steps, a [b]registry cleaner[/b] application can clear software junk or old settings that may be causing a conflict. [b]360 Amigo Speedup[/b] does the job well.[/td]
[/tr]
[tr]
11:[/td]
Remove EIO Devices[/td]
Certain hard-drives, cards, etc are EIO * devices. Identify then [b]REMOVE[/b] all of these, and see if problem vanishes.[/td]
[/tr]
[tr]
12:[/td]
Re-install EIO Devices[/td]
Plug in the EIO devices again, one at a time, rebooting and testing printer each time [u]until one causes the error[/u].
[/tr]
[tr]
13:[/td]
Still failing, all EIO devices removed?[/td]
The memory cards (DIMMS), aka '[b]D[/b]ual-[b]I[/b]nline-[b]M[/b]emory-[b]M[/b]odules' of the printer itself may be damaged or corrupt.
[/tr]
[tr]
14:[/td]
Remove Printer DIMMS[/td]
Turn printer [b]OFF[/b]. Remove all DIMMS (memory and 3rd party if any) from the printer. DO NOT remove the FIRMWARE DIMM. Printer [i]will[/i] [u][b]CEASE[/b] to function[/u]![/td]
[/tr]
[tr]
15:[/td]
Try DIMMless analysis[/td]
Turn printer [b]ON[/b]. If error 49 remains, [b]RENEW[/b] the [b]FIRMWARE DIMM[/b]. If this doesn't work, [b]RENEW[/b] the [b]formatter module[/b]. May require [i]qualified personell[/i].[/td]
[/tr]
[tr]
16:[/td]
Test for faulty DIMM[/td]
Turn printer [b]OFF.[/b] Re-insert each DIMM, one-by-one, switching [b]ON[/b] then testing error each time, then [b]OFF[/b] for next one.[/td]
[/tr]
[tr]
17:[/td]
Faulty DIMM found - NOW what??[/td]
If one of the installed DIMMS re-creates the error, [b]RENEW[/b] the DIMM with a new one.[/td]
[/tr]
[tr]
18:[/td]
Hookup everthing again[/td]
Once all tests have been done, [b]restore[/b] all printer / computer [b]cables[/b] to the way they were before, for normal operation.[/td]
[/tr]
[tr]
[/td]
* EIO[/td]
No, NOT vowels of the alphabet. In this case it's an acronym for [b]E[/b]lectronic [b]I[/b]nput [b]O[/b]utput device[/td]
[/tr]
[/table]
In fact, the above steps can apply to [i]any[/i] printer, as well as many other computer peripherals.
Causes of the error can vary, including but not limited to:
electronic failure, power surges, strong EM fields, static, corruption, etc.
First, if you don't have one already, suggest you invest in a socket or multiplug outlet with a built-in '[b]Surge-Arrestor[/b]'.
A good, updated AV is also a necessity to safeguard against cyber-attacks (see [i]corruption[/i] above).
Why i can not go to sit for configure DAP-1360
Go to this link http://support.dlink.com/ProductInfo.aspx?m=DAP-1360 and download the user manual for your DAP-1360. Configure it in the WISP mode following the manuals instructions.
Nat n300
You turn on NAT (Network Address Translation).
It turns local addresses into internet packets, so that the same device gets the response from the other end.
This router doesn't have NAT, only a firewall.
see manual
http://www.downloads.netgear.com/files/GDC/WNR3500LV1/WNR3500L_SM_11JUN2010.pdf
BONSOIR JE CHERCHE UN MANUEL DE RÃ?PARATION POUR JEEP GRAND CHEROKEE 3.1 TD . MERCI
Accédez à votre magasin pour pièces automobiles et d'acheter un Haynes ou Chilton reapir manuel pour votre modèle de Jeep et de l'année. Ils sont très utiles et vous permettra d'économiser des centaines des coûts salariaux.
Bonne chance et merci pour votre question et j'espère que mes suggestions aider. N'oubliez pas de taux de moi.
burdfrenzy
Visitez ma Boutique eBay! http://stores.ebay.com/Pittsburgh-Joes-Pants-Nat
Motorola SBG900 NAT problem.
Nat can be turned off in the sbg900, but not recommended, as it also shuts down the dhcp, which is responsible for providing ip addresses to you PC,xbox etc.. I do not believe there is a work around. Nat sometimes limits certain games, but I have not found any games other than COD that I have ever had problems with. bottom line, if you need to disable nat, then you will need to plug directly into modem.
Nat type changes back on ps3
you need to make sure that when you change it that you apply in your modem setup page that bridge mode is activated so that it turns it into a dumb unit allowing just to pass through the internet stream thus allowing constant nat 2 connection
Top TP-LINK Computers & Internet Experts
 Mikey
Mikey
Menachem Grossman
Menachem Grossman
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
