LG 47LM6200 - 47" Class LED 3D Cinema HDTV - 1080p, 1920 x 1080, 16:9, Logo
J
John Ser Posted on Jan 13, 2014
My television can't switch on
I cant switch on my tv. I on the main power switch, and the tv red light turn on and blink twice and it went off. After that i try switch on the tv using the remote and the tv switch itself, it cant turn on. Please help
adrian thompson
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Jan 13, 2014
adrian thompson
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1141
Points
Have you tried turning the tv off for 4 to 5 hours unplugging it
My Sony Bravia TV - Model #: kdl-52z5100 no longer powers on. There's a red light that blinks twice whenever I attempt to power it on. Please help
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
1helpful
I cant get sony trinitron to turn on. the standby/timer red light blinks several times and it wont turn on what can i do i am bored without tv
Likely damage to main power supply-------try to see if there is a specific number of blinks then a pause and repeats like 7 blinks a pause and repeats---that is an error code if there---with it AND THE MODEL NUMBER OF THE TV I might be able or not to help.
I have purchased a insonic tv master remote and it didnt have any instructions with it. I need to program it to my phillips tv
press tv. then press the red and select at the same time light will blink twice enter 0081 if tv turn off press select then tv! if it don,t turn off press tv then select and red together light blinks twice! now press power on and off switch until tv turns off when it turns off press select to store code
So my urc-3021 used to work for my durabrand television. I went away for a few months and came back and the batteries needed changing. I changed them and the remote didn't work for the tv (although the...
then 0178 is not the right code if the light blinks twice try code search turn the tv on press tv then hold setup till it blinks twice then point the remote at the tv then press the power button repeatedly till the tv turns off then press the tv button again
2helpful
Hi i have lost instruction manual for my total remote urc 11-4110 b02 Universal Remote could you tell me how to code it to tv manually please
@font-face { font-family: "Cambria"; }p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0cm 0cm 10pt; font-size: 12pt; font-family: "Times New Roman"; }div.Section1 { page: Section1; } SET UP
TV
The Search Method
If your device does not respond to the TOTAL CONTROL after you have tried all the codes listed for your brand, try searching for your code. The Search Method allows you to find the code for your device by scanning through all the codes contained in the memory of the TOTAL CONTROL.
To search for your TV code:
1 Switch your television on (not on standby) and aim your TOTAL CONTROL at your TV.
2 Press the TV key on your TOTAL CONTROL.
3 Press and hold down SET UP until the red light blinks twice. (The red light will blink once and then twice)
4 Press 9 9 1. The red light will blink twice .
5 Now slowly, alternate between POWER and TV, over and over, until your television turns off. You may have to press these keys many times (up to 150!), so please be patient.Remember to keep pointing the TOTAL CONTROL at your television when you press these keys.
6 As soon as your television turns off, press SET UP.
The TOTAL CONTROL remote should now be ready to operate your device. Turn your device back on and try all the remote’s functions to ensure they are working
properly. If some of the TOTAL CONTROL’s commands are not operating correctly, try the search method again. You may be using the wrong code.
Once you have Set-Up your TOTAL CONTROL, you can blink back your SET-UP CODE for future reference.
Example: To blink out your Television code:
1 Press TV once.
2 Press and hold SET UP until the red light blinks twice (The red light will blink once and then twice).
3 Press 9 9 0. The red light will blink twice.
4 For the first digit of your four-digit code, press 1 and count all the red blinks. If there are no blinks, the digit is "0".
5 For the second digit, press 2 and count all the red blinks. If there are no blinks, the digit is "0".
6 For the third digit, press 3 and count all the red blinks.
7 For the fourth digit, press 4 and count all the red blinks. If there are no blinks, the digit is "0". Now you have your four-digit code.Make sure you write your Television code for easy future reference.
My Sony Bravia turns itself off Stand by red light blinks twice.
If you bought it brand new from a dealer, I would take it back or have them come out and look at it. Less than a month old, it is still under the 1 year MFG warranty or the very best a 30 day one.
1helpful
2answers
Went on vacation came home Olevia LT20HVK wont turn on red light flashing on power button help''I cant find my owners manual and cant find one online Thank You for any Help
When the red light flashes its a indication that the main-board or the power supply is having some problems..could happen with power outages or power spikes.. this only means the main-board or power supply will have to be repair or replace.. One last thing you want to try is leaving the television overnight unplug from the power and then plug it back in the next day.. if it still reacts the same then the tv has to be service.
Since the Manuf. of olevia is out of buss.. there is a 3rd party service center called Amergence Technology Inc. that is able to service olevia TV's.. there number is 866-965-3842 im sure they are able to give you a repair quote on it...
Top LG Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
