S anand, why not start your own post?
nx6310? same?
it needs a new key board,
why not buy one and fix it
or have a skilled technician fix it, no lack of those with billions of PCs now.
that is an old COMPAQ PC, now owned by HP.
the pc has no support. in fact the HP forum , has all old questions on it in the ARCHIVE ,sections. (dead zone I call it)
in this case, we buy used keyboards off ebay.
ever heard of them,
now that bad news. there are like 100 keyboards.
the service manual covers this.
show them , 1 for each country on earth it seems.
so you need to learn what part number keyboard matches your country then buy one.
not easy or hard now, lacking said manual
the best time to get manuals is when the PC is less that 10 years
old from HP, or you get lost in the SANDS OF TIME< or quick sand.
You need a switch that matches the same switch that got ripped off. Solder back in place a new one
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
hope this helps
