Dell Vostro 1510 Laptop Computer   PC Desktop Logo
Rudi Posted on May 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blue Screen c000021a
Windows XP Pro, Service Pack 2, Bios A10. Laptop will not boot to OS. Error message "STOP: c000021a {Fatal System Error}. The Windows Logon Process system process terminated unexpectedly with a statu of 0xc0000005 (0x00000000 0x00000000). The system has been shut down." Laptop does boot to safe mode. Cannot rollback to previous good configuration. Cannot complete system restore - after reboot get a message that system restore failed. HD is listed in the BIOS setup. Attempted to run repair from XP CD, and Setup "did not find any hard disk drives installed on your computer". After attempt, my HDD Password is Frozen. Pressing F9 Setup Defaults unfreezes HDD Password. After reboot, I go back to BIOS Setup, shift the CD drive to the top, restart, boot from CD, press R, no drive found, etc.
  • Rudi May 27, 2009
    Hi LMITC - the problem was not the computer name - it was actually only my first name anyway, and although I tried shortening that, it did not good.
    Stanalichthbr - I think swapping out the hard drive is beyond what I am willing/able to do...
    additional info - the Device Manager says the HD is working properly.
  • Anonymous May 11, 2010
    Did you sort your problem.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 27, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1652
Points
Boot system into safe mode. locate the icon for my computer. right click and go to properties. locate the computer name tab and select it. find the radio button for "change" and click it. rename the computer to something considerably shorter then what you have. the system cannot boot and complete the logon process if the computer name is longer than 200 "bytes"
Anonymous
Level 2:
  • Expert 53 Answers
Anonymous
Expert
Level 2:
Answers
53
Questions
0
Helped
17669
Points
142
Next step is remove hard drive and see if it is recognized in another computer. The Hard Drive could just be bad, but you need to rule out the motherboard drive controllers that could also be bad. Also try a known good drive in your system.
Char S.
  • Anonymous May 27, 2009
    First Time I read this I somehow missed where you said you can boot into safe mode. Can you try to disable any start up programs or processess using msconfig from start-run menu. and then try rebooting. You may have a virus or malware causing this trouble.
    Char S.
1helpful
Blue screen error STOP: c000021a {Fatal System Error} The windows logon process System process terminated unexpectedly with status of 0x0000005 ( 0x00000000 0x00000000). The system has been shut down.
It appears that your Windows Registry is corrupted. You can try to use a Registry repair utility like CCleane to fix it. If that doesn't work you will have to reload Windows OS (Operating System). For more info no this error code Google "c000021a".
2answers
When I shut down windows xp it restarts I stopped auto restart and got a blue screen with this disciption on it Stop: c000021a [Fatal system error] 0x00000000 (0x00000000 0x00000000). any idea
Click on my computer.
Right Click on the C: drive.
Choose Properties.
Tools tab.
Error checking: Check now.
Choose automaticly fix file system errors.
Start, Yes, OK, Reboot the PC.
On boot a blue screen will launch and run for 5 - 20 minutes.
It wll reboot into windows when completed.
Hi, My laptop doesn't boot up. I got a blue screen with the following error message- STOP: c000021a {Fatal System Error} The initial session process or system process terminated unexpectedly with a status...
Thats known as a blue screen of death. you simply have to put in an operating system CD which is bootable (the one which you are currently using win xp vista or whatever) just boot through the cd ignore the first repair option and hit enter when the option for repairs appears for the second time just hit R and follow the options. you won't loose any data.
1helpful
The error message says fatal system error.
Hi. The STOP 0xC000021A error occurs when either Winlogon.exe or Csrss.exe fails. When the Windows NT kernel detects that either of these processes has stopped, it stops the system and raises the STOP 0xC000021A error. This error may have several causes. Among them are the following:
  • Mismatched system files have been installed.
  • A Service Pack installation has failed.
  • A backup program that is used to restore a hard disk did not correctly restore files that may have been in use.
  • An incompatible third-party program has been installed.
Booting the computer to its Last known good configuration will resolved the issue. Please see procedure below:
Turn of the computer
Keep on tapping F8 key the moment you press the power button
You should be getting a advanced boot screen
Select Last known good configuration from the selections then hit enter
Computer should be booting up by now to windows
All the best!
I have a problem on this cod c000021a fatal system error i have window when i shut down my computer show blue screen with this cod c000021a fatal system error and computer restarts i need help for solve...
Blue Screen system error. If you've been running windows Xp, please do the following:
1. Insert Windows XP CD in the Pc.
2. Restart the PC and while in Bios, go to Boot Priority and select Boot from CD as your first priority.
3. Save and exit.
4. The PC restarts and follow the instructions on the screen. (Press any key to boot from the CD).
5.After system has finished, such will happen <Enter-To Continue R-Repair ESC-Cancel>.
6. Choose R to repair.
7. A black screen pops up, just read and type 1 and wait for the next step (password).
8. Put in your Admin Password or press "Enter".
9. Then type CHKDSK and press "Enter".
10. the system will repair the errors within the HDD and windows and later restart the PC. Good luck
1helpful
I have a dell desktop running Wondows XP 2000.
There are lots of possibilities like faulty ram or may be virus in the system or may be the windows file is corrupt try to repair the windows installation. or take the backup of system and the format the system
1helpful
2answers
My pc`s screen is blue and it sais stop:c000021a ,is there? anything I can do to fix it
hello there
here is some information that should be able to explain this error and how to fix it ok?
best regards michael
  1. How to troubleshoot a "STOP 0xC000021A" error ... presents advanced troubleshooting steps for the STOP 0xC000021A error. ... STOP: c000021a {Fatal ... Note Most STOP 0xC000021A errors occur because Winlogon. ...support.microsoft.com/kb/156669
  2. "STOP: c000021a (Fatal System Error)" Error! RE: "STOP: c000021a (Fatal System Error)" Error! Ya, thats what I thought I might have to do ... RE: "STOP: c000021a (Fatal System Error)" Error! just input the ...www.msghelp.net/showthread.php?tid=66202 - 52k - Cached
  3. How I fixed my Windows XP Stop c000021a {Fatal System Error} with ... How I fixed my Windows XP Stop c000021a {Fatal System Error} with Knoppix Linux. 2008 March 14 ... Message: Stop c000021a {Fatal System Error} The Session ...healyourchurchwebsite.com/2008/03/14/how-i-fixed-my-stop-c000021a-f... - 53k - Cached
1helpful
STOP: c000021a {Fatal System Error} .. 0xc0000005
The first thing you should do is back up the HDD, Remove the HDD from your Laptop, you find the lid that opens the HDD access slot under the laptop or ask someone who knows how. if available there are aftermarket 2.5 HD enclosures that lets you install the 2.5 in.hdd of your laptop via a usb. you can plug the usb to a desktop PC and backup your files. then reformat your hdd. reinstall the hdd to your laptop. replace your memory ram which causes the blue screen with a new ram, reinstall the OS.
1helpful
Blue Screen of Death
You'll need to setup the Acer laptop to boot from CD-ROM. Push either the F2 or F10 button when booting your laptop and it should bring-up the configuration management interface. Go through the options and confirm that Boot From CD-ROM is at the top of the list on bootable devices.
Next, you'll need your original Windows XP CD that came with the Laptop. Put it in the CD-ROM Drive and reboot your laptop. You will be given two options: 1) Re-install Windows or 2) Repair the existing Windows Installation. I recommend that you repair the existing Windows Installation as this will not destroy and data or device drivers that are install on the laptop.
Good Luck!
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
