yellow- constant
red -accessory
blk-ground
blue/yellow-steering volume
solid blue- power antenna
blue/white-power contd;
orange/white-illumination
lightgree-parking brake
purple/white-back up camera
positive speakers wires are'''
white-left front
gray-right front
green-left rear
purple-right rear
negative speaker wires are'
white/blk-left front
gray/blk-right front
green/blk-left rear
purple/blk-right reat
1993 Jeep Grand Cherokee Stereo Wiring
Constant 12V+Pink
Switched 12V+
Purple/White
Ground
Black
Illumination
Orange/Black
Dimmer
n/a
Antenna Trigger
Green/Red
Antenna
Right Front
Front Speakers
6 1/2" Doors
Left Front (+)
Green
Left Front (-)
Brown/Red
Right Front (+)
Purple
Right Front (-)
Blue/Red
Rear Speakers
6 1/2" Rear Doors
Left Rear (+)
Brown/Yellow
Left Rear (-)
Brown/Blue
Right Rear (+)
Blue/White
Right Rear (-)
Blue/Orange
1987-88 Plymouth Voyager Stereo Wiring
Constant 12V+
Red
Switched 12V+
Red/White
Ground
Ground/Back Strap
Illumination
n/a
Dimmer
Orange/White
Antenna Trigger
Yellow
Antenna
Right Front
Front Speakers
5 1/4" Dash
Left Front (+)
Green
Left Front (-)
Green/Yellow
Right Front (+)
Purple
Right Front (-)
Purple/Yellow
Rear Speakers
6" x 9" Tail Gate
Left Rear (+)
Brown
Left Rear (-)
Brown/Yellow
Right Rear (+)
Blue/Red
Right Rear (-)
Blue/White
use at your own risk. I can not confirm these.
+12V DC Battery(Constant)
Yellow/green
31
15 Amp
Fuse box on left front of engine compartment, near battery.
Switched Accessory
Purple
6
10 Amp
Fuse block behind left side of dash
Power Antenna
NCA
Green for antenna signal
Illumination
Red/yellow & red/blue
Steering Wheel Control Wire
Red/white, green, and blue
If equipped, as for Mid-Line.
Left Front +
Blue/white
Left Front -
Blue/red
Right Front +
White/black
Right Front -
Blue/black
Left Rear +
Green/yellow
Left Rear -
Black/yellow
Right Rear +
Blue
Right Rear -
Red
AT SPEAKERS
Wire Function
Color
Note
Left Front Tweeter +
Blue/white
Left Front Tweeter -
Blue/red
Right Front Tweeter +
White/black
Right Front Tweeter -
Blue/black
Red = ground black = ground Grey/blue = Left rear (+) yellow/black = ignition 12v white/purple = right rear (-) green/black
= (could this be green / violet?) than it is 12v constant blue/red = illumination orange/green = left front (+) white/green = right front (-) blue/white = left front (-) brown/yellow = left rear (tan / yellow) (-) green/orange = right front (+) orange/red = right rear (+) blue = not used
Thanks for using FixYa. The wiring color code for 1996 toyota camry stereo are as under--
Constant 12V+ Blue/Yellow Switched 12V+ Gray Ground Brown Illumination Green Dimmer n/a Antenna Trigger Black/Red Antenna Driver's Pillar Front Speakers 5 1/4" Doors Left Front (+) Pink Left Front (-) Purple Right Front (+) Light Green Right Front (-) Blue Rear Speakers 6" x 9" Tail Gate Left Rear (+) Black Left Rear (-) Yellow Right Rear (+) Red Right Rear (-) White
Please do rate the solution and revert for further assistance.
red -Acc power yellow -12 memory power black -ground blue -amplifier remote blue/white -power antenna SPEAKERS white left front + white/black left front - grey right front + grey/black right front - green left rear + green/black left rear purple right rear + purple/black right rear -
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground dark green = left front spkr + purple = right front spkr + blue/white = right rear spkr - brown/blue = left rear spkr - brown/yellow = left rear spkr + blue/orange = right rear spkr + black/yellow = park lamps brown/red = left front spkr - orange = dimmer signal pink = fused battery + green/red = radio choke relay red/white = fused ignition blue/red = right front spkr -
Not a whole I can do to help. What I can do is refer you to go get a Chilton, or Haynes manual thac voers your Plymouth Voyager. They have schematics with wire colors labeled.You will have a good shot at figuring out which wire is which.
