SOURCE: Ice not dispensing and water not coming out
Our ice maker is not working..water is coming out just fine...the bar is down but not making [email protected]
SOURCE: Water Not Dispensing
HI, this is a defective dual water valve assembly. have this damaged inlet water valve device replaced asap, if possible.
SOURCE: not making ice
check to see if the water line is frozen where it enters the freezer, this is the most common cause if the water valve is ok.
SOURCE: I have a Hotpoint Refrigerator Model HSS25GFPH and
My daughter's Hotpoint has the same problem (not sure of the exact model). Discovered that the water line inside the freezer door is freezing up. However, I don't know why and the dealer says they have no clue either. This may be your problem.
SOURCE: Refrigerator makes ice and dispenses ice, but does
could be valve, it is located underneath on back. it also could be the mother board. Check valve with ohms metter. Also make sure water resevior or water lines are not frozen inside refrig section. Also water feed line going up through door bottom hinge on freezer is not frozen. Disconnect at couplin at left bottom front and blow through line
