Computers & Internet Logo
J
Judy Sediti Posted on Jan 13, 2014
Create blackberry id
How to create an
hubert muparamoto
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 19, 2014
hubert muparamoto
Contributor
Level 1:
Answers
Questions
0
Helped
252
Points
0
I want to create a blackberry id
How to activate my blackberry id
Once you created your BlackBerry ID, you just need to associate it on your BlackBerry Device.
Go to Option>Device>BlackBerry ID
How can i get my balckberry id
To create your Blackberry ID, you can visit www.blackberryid.blackberry.com
Hope this helped.
What is my blackberry ID I forgot it?
If you forgot your blackberry ID try contacting the bbm crew, or create a forum at http://us.blackberry.com/support/support-lander/Consumer.html?lid=us:bb:Support&lpos=us:bb:Support
Hey guys . I have a blackberry mob and it was working well . I have changed my blackberry id and then bbm doesn't work since I did that . I removed it many times and reinstalled it but it doesn't work
Greetings,
Try going to this web page :
Forgot my BlackBerry ID Password And Recovery Question
and check the last reply on the page:
Re: Forgot my BlackBerry ID Password And Recovery Question.
Start first with these please:
  • KB28685 How to reset the BlackBerry ID password using the password recovery question
  • KB32111 "The link is no longer valid." is encountered when attempting to reset a BlackBerry ID password
  • KB26361 How to change or reset the BlackBerry ID password
  • KB28111 Unable to reset BlackBerry ID password when using a BlackBerry hosted email address
  • KB28232 BlackBerry ID reset email is not being delivered to the associated mailbox
If you have forgotten your BB ID credentials AND have non-BB access (e.g., Outlook, webmail, etc.) to the email account that is currently configured to your BB ID account, then those instructions should allow you to recover access to your BB ID account.
However, if you do not have access to that email account, then your challenge is much greater, and you have a choice to make depending on your circumstances:
  1. If you have no AppWorld records that you require to retain (e.g., purchase records for apps), then simply abandon the BB ID and create a new one. To do so, however, does require a device WIPE:
    • KB26694 How to change the BlackBerry ID on a BlackBerry PlayBook tablet or BlackBerry smartphone
  2. But, if you do have AppWorld records that you must keep, then you require human intervention. To receive that, you must ring up your mobile service provider and convince them to escalate your case up to BlackBerry. Further, you must convince BlackBerry to provide you with a solution -- which likely will either be resetting your current BB ID so that you can again access it or having you create a new BBID and they will manually move your purchase records over. Note that I have no idea if they will be willing to do this, but there is no other way that I know of to retain your prior AppWorld purchase records.
Blackberry password
How to recover a BlackBerry ID using a BlackBerry smartphone
Something important to keep in mind when recovering a BlackBerry ID password is that you will need to use the BlackBerry Browser on your device or a web browser in order to complete the process. This is a result of a security precaution that prevents the password recovery email from being sent to the device. To recover your BlackBerry ID password, use the BlackBerry smartphone browser or a computer to follow these steps:
1. Navigate to the BlackBerry ID password recovery page
2. Enter the email address that you used to register your BlackBerry ID and fill out the CAPTCHA characters
3. A confirmation page will appear stating "A request to reset your password has been submitted"
4. Open the mailbox for your email address on the computer or by logging into the mailbox\webmail using the BlackBerry Browser and click on the BlackBerry ID password reset email (it can be identified by the sender: [email protected])
Note: Don't forget to check your spam/junk folder in the event that you do not see this email in your inbox.
5. In the body of the email, click the link after the heading "To change your BlackBerry ID password, simply visit"
6. The link will open a new page in your web browser, enter your new BlackBerry ID password in both fields and click Submit
7. You have successfully recovered your BlackBerry ID password!
How to recover a BlackBerry ID using a BlackBerry Playbook tablet
To recover your BlackBerry ID password using a BlackBerry Playbook tablet, follow the steps below. Something to keep in mind is that you may be asked for the answer to the security question that you created during the initial setup of your BlackBerry ID.
1. On your BlackBerry Playbook tablet, open "Options" by taping the gear in the top right corner of the Home Screen
2. From the menu on the left tap "BlackBerry ID"
3. Tap the Pencil icon to the right of "Change Password"
4. Tap "Forgot password?"
5. Enter your password recovery question which you created when the B BID was initially set up and tap "OK"
. Open "Messages" on your BlackBerry Playbook tablet or log into your mailbox/web mail using the BlackBerry Playbook tablet browser and select the email from [email protected]
7. In the body of the email, click the link after the heading "To change your BlackBerry ID password, simply visit"
8. The link will open the web browser on the device, enter the new password in both fields and tap "Submit".
  • That's all there is to it!
Want to create new blackberry id
Perhaps you try this on he Blackberry site, with the link below here.
Create BlackBerry ID
2answers
Creat a new blackberry id
    • Do one of the following: When you first set up your new BlackBerry smartphone, click Create a BlackBerry ID. ...
    • Complete the fields on the screen. The mandatory fields include a username (which is an email address), password, screen name, password recovery question, and password recovery answer.
    1. Create a BlackBerry ID using your smartphone - User Guide ...
  • BlackBerry Manuals Help
    Create a blackberry ID
    PLease create the blackberry id on this link.
    http://in.blackberry.com/bbid.html
    Cannot set up BBM an error occurred with blackberry id
    You will need to setup your blackberry ID, visit www.blackberryid.blackberry.com/bbid/createaccount to create a blackberry ID.
    Best regards
    Oct 05, 2013 • Cell Phones
    How can I get my blackberry id
    If you don't have a Blackberry id, you can create one when you setup a new tablet or smartphone or when you attempt to 1st use a product or service that requires a blackberry id.
    thanks
    craig.
    Grand Canyon Tech
    Grand Canyon Tech
