SOURCE: I have just installed 2 Leviton decora switch with
This is a single pole light switch and should be wired as any other SP switch. The only difference is that is has a pilot light. All the white neutral wires are tied together and then pushed back in the box with none connected to the switch. The grounds are tied together with a jumper wire connected to the green screw on the switch. That will leave you with 2 or more black wires. If you have just two normally you can connect them to the two screws on the switch and it does not matter which screws. However it may be that with the pilot light you need to connect the wire going to the light to the top screw and the power wire to the bottom or vice versa. Try both ways. If you have more than 2 black wires you need to connect the incoming power black wire and outgoing power black wires together and then jump to one of the screws on the switch. The black wire left over is the black wire going to the light itself. If none of this works then it is obvious the pilot light in the switch is burnt out.
Testimonial: "Thanks a million. I will recheck the wiring tomorrow. Chas"
SOURCE: I have two Leviton Decora Motion Activated Light
Unfortunately you cannot use two PR180-1LA's for what you want to do. :-( There is only one correct installation:
One PR180-1LA needs to be installed at the switch box which contains the cable that goes to the light (load). That is a must. One then installs a regular 3-way switch at the switch box which contains the cable with the hot from the breaker (line or source).
If you reverse the sensor location you will need 4 wires between the switches, which is not usual practice, as the bare grounding wire is not permitted to carry current per National Electric Code rules.
If you want a sensor at both locations you need to install a IPP15-1L at the switch box that has the cable going to the light (load). One must then install a IPP0R-1L at the switch box that has the cable with hot from the breaker (line or source).
SOURCE: I am trying to replace a two wire light
one of the white wires has power on it constantly....that wire connects to the black wire of the leviton.......the other white wire which has no power to it is going to whatever needs power so that wire connects to the red wire of the leviton....the green wire connects to the metal box where your mounting the leviton.
SOURCE: I installed the motion sensor
Leviton manuals:
http://www.leviton.com/OA_HTML/ibeCCtpSctDspRte.jsp?section=17219&minisite=10022
A quick peek inside a sample Leviton manual confirms that your wires are connect correct - BUT...
http://waterheatertimer.org/pdf/Leviton-motion-Instructions.pdf
The remaining 3-way switch needs a jumper wire.
See if your instruction manual shows the same thing as image below.
Let's go through this.
The yellow wire connects to a traveler ... and that traveler connects to one of the brass screws on 3-way switch.
The black wire from Motion sensor also connects to a traveler wire ... BUT you have to identify which traveler wire and which brass screw that traveler wire connects to. And then, put a jumper wire (a short piece of wire) from that brass screw to the dark-colored screw.
I think that will do it.
Add a comment if your device is different.
Some of these electronic devices are reversed when two of their wires are connected together.
That's what the jumper wire is doing. So the 3-way switch is just connecting and disconnecting the black and yellow wires, and that action reverses the circuit in the motion device.
SOURCE: replacing a single pole switch
The old single pole switch has 2 black wires.
One black wire is hot from circuit breaker box, and the other black wire goes to load (light, fan, motor)
New device has black wire: connect this to hot from circuit breaker box.
New device red wire: connect this to load wire
New device has white wire: connect this to Neutral wires.
Neutral wires are white wires that are twisted together and covered with wire nut and pushed to back of box. If your box does not have neutral wires, then connect device white wire to bare ground wire.
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on electrical or any do-it-yourself project.
Fixya is always less expensive than a service call.
1. With power restored and wallplate removed, use your finger or a small screwdriver to adjust the light sensitivity and time settings on the device as follows:
Light Level Adjustment:• Turn the control towards the "+" sign. Lights will turn ON in lighter conditions.• Turn the control towards the "-" sign. Lights will turn ON in less lighting conditions.
Time Selection:• Adjust the time selector to the desired length of time the lights are to remain ON. Lights will remain ON from15 seconds to 15 minutes after the room is vacated.
• Turn the control towards the "+" sign. Lights will remain ON up to 15 minutes.
• Turn the control towards the "-" sign. Lights will remain ON up to 15 seconds.
2. Test that the light level and time selection are as desired. If not, repeat adjustments until satisfied.
The manual is here:
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?item=8018§ion=17219&minisite=10022
