Computers & Internet Logo
s
steve dardeen Posted on Jan 12, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Gps app wont open
Tap on it and it wont open
Glyn
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 123 Answers
  • Posted on Jul 10, 2014
 Glyn
Expert
Level 2:
Cheetah:
Answers
123
Questions
0
Helped
33004
Points
253
Remove it & reinstall
1helpful
2answers
How to log back into facebook after getting a new phone.
Hi
Just open Facebook app and open it fill your login detail.
If forgot password click on forgot password and reset the same via SMS code confirmation.
2answers
I have an Apple Watch 3. It continually loads silent mode and the weather app by itself. The weather app flashes continually. I have unpaired and re-paired. Now turned off cover to mute. Any help
You didn't mention which iPhone model it's paired with, but here are two things you could try:
- erase the Apps on you watch and on your iPhone, and reinstall them.
- using your web browser (Safari), search for "how reset your Apple Watch 3"
I was having trouble losing satelite connection every 30 seconds. GPS has now gone off and will not switch on
To fix this, you can use an app like GPS Status & Toolbox to clear your GPS data and to start connecting to satellites from scratch. In the app, tap anywhere on the screen, then tap the menu icon and hit Manage A-GPS state. Tap Reset, then when that's finished go back into the Manage A-GPS state menu and tap Download.
Apr 17, 2019 • GPS
I have Google maps on my phone how do I get sound on it when Iam driving,My phone is cinnected to the radio in the car
Google maps starts sound when ur in navigation mode.
  1. Open the Google Maps app .
  2. Search for a place or tap it on the map.
  3. In the bottom right, tap Directions . If you touch and hold the button instead, you'll start navigation and can skip steps 4-6.
  4. Optional: To add additional destinations, go to the top right and tap More Add stop. You can add up to 9 stops. When you are finished, tap Done.
  5. Choose one of the following:
    • Driving:
    • Transit:
    • Walking:
    • Rides:
    • Cycling:
  6. If other routes are available, they will be shown in gray on the map. To follow an alternate route, tap the gray line.
  7. To start navigation, tap Navigate . If you see "Searching for GPS," your phone is trying to get a GPS signal. For example, you might be in or near a tunnel, parking garage, or other location where there's no GPS signal.
  8. To stop or cancel navigation, go to the bottom right and tap Exit.
NOTE:
Navigation is not available in all countries. depends on availability
1helpful
I need a users manual for navmii gps navigation software For Windows
https://www.microsoft.com/en-us/store/p/navmii/9nblggh10k57 = software.
Navmii used to have an old manual at http://www.navmii.net/bin/Navfree_UserGuide_v1.0.1.pdf
The link no longer works.
Here are some basics:
Basic Navfree Help
Navigation is easiest if locations are added to Favourites before navigating. To check a location before adding it to Favourites, or find a location near another location:
Tap Menu icon at bottom right of map screen. Tap Navigate on Main Menu. Tap Address or Google.
Type name to find. Done. Tap down-arrow beside item . Tap Show on map.
Check it is the correct place. If so tap down-arrow and Add to Favourites.
Or drag map to required location. Tap on map. Select Add to Favourites. Change name if required.
To enter a route from A to B, when A is not the current GPS location.
Need to disable GPS in Android Settings - Location.
Easiest if A and B are entered into Favourites. Use Google Search or Address to find names and descriptions, then Add to Favorites.
Then tap Navigate on Main Menu. Tap Favourites and select A.
Tap box with Favorites name in it, and select 'Route from Here'.
Tap Menu icon at bottom right of screen. Tap Navigate. Tap Favourites.
Tap 'Route here'. Tap 'Selected' (not Gps).
Tap 'My Route' to see Route on map.
To clear route: From Main Menu, tap Clear Route.
Cant edit or delete (sometimes) Favourites. Use Jota app . See forums.
Still looking for manual, there blog is very helpful which is the link above.
Helpful links,
https://groups.google.com/a/navmii.com/forum/#!forum/android-app
https://groups.google.com/a/navmii.com/forum/#!topicsearch/user$20manual/android-app/CibF963hA5I
1helpful
2answers
I recently did a factory reset on my gps 84h-3 and now my navigation will not open but the rest of the icons open just find
On the main sreen you have an app that looks like two arrows one pointing right the other left. Clich/tap on this icon then tap select \SDMMC\ destinator exe. This will get you back on track. All of your previous maps will be available if you saved them.
Aug 08, 2013 • GPS
I can't sign out from my facebook account to open another one
from the app or from the browser or sync ?
go to accounts & sync tap on Facebook -> uncheck sync
from the app just press back until you exit
browser you could press menu -> windows -> close the facebook window -> then press back
2answers
Gps is not working. no error message.
If your GPS is not working, charge the battery of your gps, if it is not still working, i will advice you get a new battery on the gps because it is possible that the battery on the gps might have gone bad, change the battery and see if it will work.
Need more information, leave comment.
Take care.
How do i change the apps instructions from another language back to english
go into change preferences , tap arrow till you see change language , tap then select your required language click DONE
How to use gps in iphone 3g apple
simply tap on "maps" on the homescreen to open the Maps application. Then tap on the little circle in the bottom left corner to locate yourself using the gps module.
Out of the box, the iphone 3g doesnt support turn-by-turn directions like your usual tomtom gps system.
You can download apps for that when youre on softwareversion 3.0.
Grand Canyon Tech
Grand Canyon Tech
