6510 photoSmart printer
SOURCE: HP Photosmart C6100 All-In-One Printer stopped printing black ink
Please clean the print heads :
Press Setup up - Tools - Clean Print heads on the All-in-One.
If this does not resolve the issue , Reset the All-in-One.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord.
If issue stil persists. Contact HP.
SOURCE: HP 3210 black ink problem
I just posted my problem and found the solution on a different web page. It is this and it WORKS
All you have to do is HOLD DOWN FOUR BUTTONS AT THE SAME TIME: ( OK, Cancel, Black , Color ) and turn the power off. Do this at least twice and the unit will power up and go to maintenance. Then it was back to normal.
HP gives you a procedure that doesn't work! They just want to sell you a new one. They must know the solution if and old woman like me can figure it out with help from other people with the same problem
SOURCE: hp 3310 photosmart only prints in yellow
On the left side of the print head carriage is a white plastic gear that drives the ink pump. Check it first to see if its firmly in place, has chipped or worn off teeth or looks damaged in some other way.
If this white gear driving the ink pump is damaged or looks odd let me know right away so we can address this issue.
Now, there is a trick for resetting your particular HP printer. This sounds and is convoluted but it will work. However, the system will think all your ink cartridges are full. If they are rather full okay. If they are near empty you will want to run this hack again as the ink nears low. You won't get a ink low warning correctly after this until you've installed new full tanks eventually.
Turn the printer on. At the same time, using your left hand, press the OK, Cancel, Black, and Color buttons down and hold them down. While holding these down buttons use your other hand to turn the printer off, still holding the four buttons down with the left hand. Once the printer has powered down fully you can release the buttons. Now, the printer will initialize and then run a maintenance check. If you printer is otherwise okay, no damaged circuitry or gearing you will be fine. Turn the printer on. It will start up and shut itself off, this is expected. Once it is off again, turn it back on once more and this time the printer will run the maintenance routine. Have paper in the feed tray.
1.) Check left side of printer carriage for the white gear that drives the ink pump. Look to see if the gear is off, broken has worn or chipped teeth.
2.) Turn the Printer On.
3.) Hold down the OK, Cancel, Black, and Color buttons with your left hand and hold them down.
4.) Use your other hand to turn the printer off. Keep your left hand on the buttons until the printer is off.
5.) Turn the printer on, wait for it to turn itself off. Have paper in the feed tray.
6.) Turn it on again and it will enter the maintenance mode. Follow any prompts during the maintenance mode, if any.
You should be back in business now. If not, try the routine again, sometimes you have to run it more than once. Should it still fail, let me know as you may get an error message and error number.
Use the Comment Text Entry Box below to comment back with any other questions or point out failures in this hack.
Regards,
Worldvet
SOURCE: my photosmart hp C6180 keeps saying printer
C6180 reset:
Perform a semi-full reset to set all user menu settings, telephony parameter settings, country/region and language UI, fax memory settings, fax journal information, speed dial and broadcast lists, personal header information, and junk fax settings to the default settings. Performing a semi-full reset of the All-in-One
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01457329&cc=us&lc=en&dlc=en&product=1153494
Or a Full reset:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00720248&cc=us&lc=en&dlc=en&product=1153494
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: installed new hp black cartridge 56 ink but won't print
it shows if your using refill cartridge. & if you r using refill cartridge clear cartridge sensor with soft hands your problem would be resolved.
