SOURCE: my acu-rite wireless thermometer model #00604RX
Double check the batteries and the direction in which they are installed. If there is one backwards in the sending unit that is outside, it will not send a signal. Also, there is typically one battery in the indoor unit that is responsible for receiving the signal from the outdoor unit. If all of the batteries are in correctly except that battery, you will see the display, but will not get the data transmitted from the outside sending unit.
SOURCE: I have an acu-rite 01500, which came with no
The instruction manual can be viewed and downloaded here: http://acuriteweatherstation.com/manuals
SOURCE: I have an acu-rite 592w
I know this thread is old, but I see no one answered the question - "How to remove the stand"
Grab the stand on the sides with your thumb on one side and fingers on
the other and pull down ... I had to "rock it out" or pull one end then
the other. It seems stuck but it will come off ... Another option would
be to take a small screwdriver and insert it in the small openings under
the standard gently push the tabs while pulling down on the side you
are doing. Push the tabs towards the outside of the unit not the inside
... in other words if you are working on the left hole push left (left
while viewing from the face of the unit)
