PrintCopy .infohttps://printcopy.info > code=SC390
Code: SC390; Description: TD sensor error 1. The TD sensor outputs less than 0.5V, 20 s after the TD sensor initial setting has been performed.
Missing: cod ‎' Must include: cod
Fixyahttps://www.fixya.com > ... > Ricoh
The closest thing is the sc390 code, which means either the toner density sensor or the developer has gone bad, and typically replacing the PCU can fix that ...
Copytechnethttps://www.copytechnet.com > 56632-sc-390-a
Sep 24, 2011 - I've got an Aficio 1018 that's generating sc390 after every 10 copies. I recently fitted new drum, cleaning blade and developer and changed ...
Ricoh Copier Error Code SC 554 problem
Reseting SC 554 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane) Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON Ricoh Error Code SC 554
Heating roller overheat (hardware error)
The heating roller thermistor detects 240°C or more.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
