eMachines eM250-1915 Netbook Logo
r
robert dickens Posted on Jan 12, 2014
Emachine em250 how to format hard drive back to factory
1helpful
How to factory reset a Emachines Etower 633id it boots up but says operating system not found it has Microsoft Windows ME Millennium Edititon (from Windows 2000 Professional)
  1. Boot the computer to the boot menu: To do this, restart the computer and press the appropriate key when prompted to enter the boot menu. On most eMachines computers, this is the "F12" key.
  2. Select the CD/DVD drive as the boot device: Use the arrow keys to select the CD/DVD drive and press the "Enter" key to boot from it.
  3. Insert the Windows ME boot disk: Insert the boot disk into the CD/DVD drive and restart the computer.
  4. Choose the "Start Computer with CD-ROM support" option: When prompted, choose the "Start Computer with CD-ROM support" option.
  5. Run the Windows ME setup program: The setup program should start automatically. Follow the on-screen instructions to install Windows ME.
  6. Format the hard drive: During the setup process, you will be prompted to format the hard drive. Choose the "Full" format option to erase all existing data and perform a complete factory reset.
  7. Install Windows ME: Continue to follow the on-screen instructions to complete the installation of Windows ME.
After the installation is complete, the computer should be in a factory reset state and you can begin setting it up as a new system.
Please note that resetting your computer to the factory settings will erase all personal data and installed programs, so be sure to back up any important data before proceeding with the reset.
How do i format a emachines em250 series back to factory
WHILE IN RESTARTING WHEN ACER LOGO IS SHOWS PRESS ALT + F10 AND FOLLOW THE STEPS.
My emachines em250 mini laptop says please input password for ST9250315AS
It has a hard drive password set. If you know the password then when you first boot the laptop go into the Bios and into security.. In there you will find where you can disable the hard drive password by entering it and choosing disable
1helpful
Changed hard drive on emachine e725 now says no bootable device insert boot disk. dont have boot disk
You will need to install the operating system on the new hard drive for it to boot.Also you need to set you're boot order in the bios to CD then the HARD DRIVE.Get the operating system set the bios boot order then install it.
No bootable device found
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Emachines netbook will not power up properly after fitting a new screen
Try changing different ram memory...tekgods.com
I’m happy to assist further over the phone at https://www.6ya.com/expert/jaime_08785c7d726a554e
My emachines netbook will not come on
The hard drive has issues or the windows files have been corrupted, I suggest having the hardware tested.
How to fix missingoperating systm on my em350 without disk?
( Missing Operating System ) This usually means that your Hard Drive has crashed and you need to Format the Hard Drive and reinstall Windows or maybe even the Hard Drive itself needs to be replaced . Hope this helps . . . .
My emachine em250 wont start windows 7 will not boot up at all what can i do? there is no cd drive so i cant do a recovery with a cd
If you are using Windows 7 Click on the start icon, right-click on "Computer" click on "Properties." On the left hand side are quick links, one should be "Action Center," click on it , at the bottom of the page you will see a computer icon with a clock called "Recovery," click on it and click on the blue text "Advanced recovery methods," You should see a button called "Return your computer to Factory Conditions" click on it and follow the instructions
Hope that helps
Top eMachines Computers & Internet Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
