Flash disc will not work in any usb port. The usb ports work on all other equipment. The light will not come on and nothing comes up on the computer. The information is not critical but I need it if I can get it or I will have to start over. I have even tried the stick in the usb ports at work and nothing.
If you tell me there is nothing I can do, I can go with that information but I need to know do I have to back up all of my flash disc like the floppy disc needed to be backed up
I bought a new lexar jumpdrive and I cant get it to download on my p.c.
It works on everonyes but mine. How can i get this fixed if at all?I bought a new lexar jumpdrive and I cant get it to download on my p.c.
AnonymousJan 14, 2009
I'm using my Lexar FireFly and my laptop won't recognize it. This has never happened before now, and I've used it several times on this computer. I tried to use it on another computer, but it isn't recognized there, either. I really need the stuff on there, and I swear I will never put anything else on my JumpDrive without saving somewhere else anymore. Is there any way to get it recognized?I'm using my Lexar FireFly and my laptop won't recognize it. This has never happened before now, and I've used it several times on this computer. I tried to use it on another computer, but it isn't recognized there, either. I really need the stuff on there, and I swear I will never put anything else on my JumpDrive without saving somewhere else anymore. Is there any way to get it recognized?
You can't post conmments that contain an email address.
Some flash drives have a case that is too fat to be fully inserted in usb connector of some PCs, I have has the same problem, try a short usb extension cable, worked for me.
Have the ports ever worked? Have you opened the computer icon to see if the flash drive is being detected- but maybe not auto-starting? Also, if a drive is inserted (Windows system), you ought to see the "safely remove hardware" icon appear on your taskbar, near the clock. Clicking on the icon ought to show you the drive by name & drive letter.
Lastly, right-click Computer>properties>device manager>expand disk drives>if your flash drive is shown here, highlight it & uninstall the device. Remove the flash drive, then reinsert it. Windows will reinstall the driver & this may allow it to recognize the drive again.
I believe your TV has 2 USB ports on it. If you have equipment connected to the other USB port, that port will get priority and the TV will ignore your flash stick. Turn off your tv, disconnect everything on your USB ports then insert the flash stick. Power on the TV and hopefully you can see the flash stick.
Sometimes when a flashmemory stick or USB external hard drive fails because it was not removed fromthe USB port properly. If the device is removed byjust pulling it out of the USB port, it can cause the flash device to fail, youmust click on the Safely Remove Hardware icon on the Task Bar and select thedevice you wish to remove and only do so when instructed to do so
When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management.Thenright click on Disk 1 removable drive and click Format. After the flash drivehas been formatted it will indicate that it is Healthy.
If
your computer affected by virus,then your memory card will not show in the pc .so you will
install it to another pc,and format it .Flash drive can not
recocknize,becayse there are some reason .
VIrus affected
Sometimes when a flash memory stick or USB external
hard drive fails because it was not removed from the USB port properly.
If the device is removed by just pulling it out of the USB port, it can
cause the flash device to fail, you must click on the Safely Remove
Hardware icon on the Task Bar and select the device you wish to remove
and only do so when instructed to do so.
When the flash
memory USB hard drive device appears to malfunction it may be possible
to restore it by reformatting it. Insert the flash or USB hard drive
into the USB port then Click on Control Panel - Administrative Tools -
Computer Management - Disk Management. Then right click on Disk 1
removable drive and click Format. After the flash drive has been
formatted then it will indicate that it is Healthy.
If this doesn't work then it is faulty. www.artplus.hr/adapps/eng/dpr.htm www.CardRecovery.com
Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy.
Sometimes when a flash memory stick or USB external hard drive fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so. When the flash memory USB hard drive device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management. Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
