Question about Power Acoustik PTID-5800 Car Video Player
I have a power acoustik ptid-5850n, It will not play any cd, dvd, mp3, ect., it will not play anything except sd card, usb, and radio???
I have a power acoustik ptid-5850n and all of a sudden it will not read any disc at all. It says disc error or error and wont play anything. I have only had it for a few months can you help me??? Thanks
I HAVE THE SAME PROBLEM WITH MINE CAN SOMEONE
PLEASE HELP THANKS
Posted on Jan 23, 2010
SOURCE:
My power acoustik ptid-6250 will not cut on anymore. I was listening to it and it started going in out. Then all of sudden it just went out and won't come back on. How do I fix it ?
Going in and out sounds like the antenna cable got loose, but the not turning on sounds like the fuse blew. Worth checking those 2 things out first and foremost.
Do you still have your owner's manual? If not:
http://www.poweracoustik.com/pa2012/manuals/PTID-6250.pdf
Jan 27, 2015 | Power Acoustik Car Audio & Video
I have a Power Acoustik PTID-7000NR and the cd is stuck and will not come out. It plays fien and everything else works. But the CD will not come out. Any suggestions? Thanks!
you may have two cd`s inside take the radio out and take it apart. inside the radio there is a realese for the cd tray but you have to have power to the unit for it to work. eject the cd from the front then hit the release on the inside its a little tricky but you should be able to find it
Sep 20, 2011 | Power Acoustik PTID7000NR Car Video Player
My power acoustik 8960 touch screen does not respond
return it...it will start jamming when loading a disc and the fan will start to grind soon.  it is a bad unit..like all 3 I have HAD!!!!!
Feb 18, 2009 | Power Acoustik PTID-8960 Car Video Player
Help i need a wire harness for power Acoustic dvd player
you would have to order it from poweracoustik.com. go to poweracoustik.com then go to contact and there will be a number call it an order.
Jan 24, 2009 | Power Acoustik PTID-5300 Car DVD Player
Region free code for power acoustik ptid-5300
Try the following which i managed to get from POWER ACOUSTIK technical support:
Multi-region for PTID4006T, 406T, 4005, 405, 8006T, 8004, 4003, 5000, 5800, 5300, 530.
1. Turn the unit on and insert a DVD disc. The unit will display LOADING.
2. While the DVD player is LOADING press the following keys:
SET-UP, then press 0, 0, 0, 0 key (0 four times), then ARROW DOWN key (to change the zone to region all 0), then BAND/ENTER key and SET-UP
3. To finish the procedure, push the EJECT key. The disc will eject... Wait and the DVD disc will re-load and play.
Jul 13, 2008 | Jensen VM9510 Car DVD Player
Power Acoustik PTID-4007
Ignore the above comment... SD cards and USB play fine on there (i have one).
Mine does the same, but leave it for 5-10 seconds after it says close and it loads it up!
Mar 29, 2008 | Power Acoustik PTID-4003TV Car Video...
Power Acoustik PTID-5800 Car Video Player Logo
1,264 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Dalynn Turner
Marvin
Marvin
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
