Olympus Camedia C-750 Ultra Zoom Digital Camera Logo
J
JHopper Posted on Jan 11, 2014
Power button does not turn camera on. LOVE this camera. Can deal with the battery door problem but not this. Thank you.
Henry Bucki
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 25, 2019
Henry Bucki
Contributor
Level 1:
Answers
Questions
Helped
172
Points
My latch was broken at plastic not the door but on the camera. i drilled a very small hole in the door and then into the camera. i used one of the spare very small screws that came on my ring door bell and screwed the screw into the new hole .worked great
2answers
I have a Nikon d3300 that turns off automatically after i take a photo - can you assist
If the screen display is shutting off, that's a normal function. If the camera is entirely shutting off it might be a bad battery or a very weak battery.
1helpful
How do i add a second switch to my rc8233r?
I would try Ebay first (or search the net for availability and prices). I bought CR2032 3V Button Cell (that are used in my Carlon door chime buttons) batteries. I got 10 for under $5. Carlon (Thomas & Betts) still makes a variety of door chimes and accessories. However, on their site, the prices are atrocious. But, I think that Thomas & Betts deals in bulk (as in dealing with retailers). Because they list their items in bulk price form. I personally have 5 T&B wireless door chimes. Hence, 4 of the buttons are in storage. Out of curiosity, I tried all of them. All 4 extra buttons rang all the door chimes. Caution, on the packages of the door "chimes" I purchased. There's a blurb on there that states the wireless buttons for the "door chimes" will not work with the "doorbells". If you have the packaging for the one you have. It will explain. I'm not positive, but it seems the variance is due to whether you use battery or electric powered models. Hope I was of assistance...Greg
I turned the camera on. The screen came on then quit like the batteries were dead. I replaced the batteries, then bought new ones. I cannot get the camera to come on when I move the "on"...
ths issue happens every so often on these cameras. for some reason it seems the camera has issues interacting with the lens motor and turns off. you need to make sure the len shoot is clean of obstruction and try to give it a wiggle or turn. leave the batteries out of the unit for about 5 minuts and for 10 seconds before hold the power button over. then place the batteries in the unit. this is something that i have happen to my unit atleast 2 or 3 times a year.
1helpful
My lens does not retract when I turn the camera off. I constantly get a message to turn the camera on and off which does not allow time for me to take pictures. Help! I love my camera!
hi, you may try this trick.... remove the battery and then press hold the power button for like ten seconds. then put the battery back and press power and see what happens... hope the trick helps
2answers
I dont no how to put the batteries into my mercury cyberpix s-555v digital camera. and i need help and it doesnt seem 2 turn on or i dont no where is the power on and off button. can u help 4 free. thank u
look at the battery and then the camera,matching up the positive and negative,close camera door,the on button is the little button on the left at the top of the camera,hope this helps you
Big fingers and need it simple
Tammy,
The HP PhotoSmart E317 is indeed a simple to use camera. Here's a picture of the back of the camera. TestFreaks gave it a 6.0 out of 10 -- from the experts. However, real users (consumers like you and me) gave it a 7.9 out of 10. There are very few buttons to deal with and the open/close door acts as the power off/on function. It should be a good replacement for your older camera.
I hope this helps!
Regards,
CharlieJ
[Please rate this solution, if it helps you.]
2answers
Not turning on
The batteries probably need to be replaced. Be sure that any batteries seat properly and tightly. You may have to tape the battery door shut with strong tape to keep the contact tight. This type of damage is expensive to repair compared to the cost of the cameras. You can take it in and have it looked at, but be sure to get an estimate and then you can make an educated decision on whether to repair or replace it.
Best wishes to you and Thank you for using Fix Ya!
Error Code C:32:11 Tape does not eject
try removing the button cell battery, main battery, and any other power source from the camera and let it sit for one hour. THen using only the AC adaptor, see if the camera works, if it doesn't then you may have to take it to a repair shop, cause the cassette door has malfunctioned.
3answers
Date time setting does not program
There is not an option to remember the date/time when you power off the camera. The camera should always remember the time. If it forgets the setting when you power it off then your backup battery has gone dead. Check your manual to see if it is something you can replace yourself. I am not familiar with this camera specifically but some cameras make the backup battery accessible and some require disassembly. David Millier Advance Camera Repair
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
