Every time I turn on my Craig tablet I have to re-enter all my information again. Now it has been loading for over an hour! I tried to re-set by pushing the button on the back. Nothing! I just purchased this in December and have only been able to use it a handful of times..Frustrated.
SOURCE: Nokia N800 Tablet
I had the same problem with the n810. I was using a non-oem battery and the connections were a loose fit causing the battery not able to charge.
If you take the battery cover off, hold the battery firmly in place. Connect the charger and make sure battery is charging, then press the boot button. If it boots and stays on, then shuts off when you stop holding the battery. Then you probably have a loose connection or a bad battery. Also try cleaning the connector with a pencil eraser and alcohol.
I had to wedge tthe battery in place. You can find a spare battery with a desktop charger on Ebay for around $10US.
SOURCE: i have a craig touch screen tablet and i forgot my dot password how do i reset it?
Power the unit off (holding power buttom) and selecting Power off, then hold simultaneusly back button and on buttom 8 seconds,the android icon appear press back buttom, in the menu select wipe data/factory reset pressin home buttom and then press back buttom, in the next screen select "yes delete all user data" pressig back buttom, and in the nex screen select "reboot system now" with the back buttom and wait. IT WORK FOR MY TABLET
SOURCE: I forgot my password on my craig android tablet
This solution works for
most tablets. •
Power off the tablet •
Tap Power, then press
and hold Power + Vol Down until you get a menu, then release •
Look for a Recovery or
Factory Reset option, and select it.*PLEASE NOTE THIS WILL ERASE ALL DATA,
INCLUDING THE PASSWORD*
SOURCE: How to hard reset Craig 7 inch touchscreen tablet
Didn't work still can't watch mi youtube videos hat can I do please help me??????
SOURCE: how to unlock my craig android cmp741e tablet
my child put a number lock and she forgot it and im wondering how to get around it
